Oil Temp Sensor on a '96 Question...
Old Oct 18, 2008 | 05:06 PM
GS348's Avatar
GS348
Default Oil Temp Sensor on a '96 Question...
Is replacing the oil temp sensor a do-it-yourselfer kind of task? Any roundabouts as to how much the sensor runs or any pointers in replacement? Any insight is greatly appreciated
Old Oct 19, 2008 | 03:08 PM
GS348's Avatar
GS348
Anyone?
Old Oct 19, 2008 | 03:09 PM
pr0zac's Avatar
pr0zac
its easy. its right above the oil filter
Old Oct 19, 2008 | 03:33 PM
GS348's Avatar
GS348
Terrific.....any ideas as to how much it runs?
Old Oct 19, 2008 | 05:07 PM
pr0zac's Avatar
pr0zac
i think its $30
Old Oct 19, 2008 | 05:13 PM
96GS#007's Avatar
96GS#007
Access is the only challenge since the driver's side cat is in the way. Other than that, no big deal.
Old Oct 20, 2008 | 07:25 PM
F22's Avatar
F22
Before replacing it, you might want to check the connector and the outlet spade. The oil temp as others mentioned, is right next to the oil filter. On my Corvette, the oil seepage from the heads (now repaired with new head gaskets) contaminated the heck out of the connector and lug. When you'd start the car cold, the oil temp would read 320 degrees! The female connector had long lost it's hard cap, so I douched the heck out of both connector and spade with electronics cleaner, wiped it off, then applied heat shrink tubing over the exposed connector. Hooked it up and then shrunk the tubing. No problems since. Start it up and it say's low temp and then adjusts correctly as you're driving.
To Oil Temp Sensor on a '96 Question...
