Idle problem. ...HELP please
Old Oct 19, 2008 | 11:08 AM
R RUPERTUS's Avatar
R RUPERTUS
Default Idle problem. ...HELP please
been having a crazy idle problem... now i seem to be showing a 0122 code.TP sensor circuit low voltage....Where might i start to look in order to solve this ? Thanks for your help !
Old Oct 19, 2008 | 11:54 AM
7thvet's Avatar
7thvet
I guess you would start by checking the connection to the TPS,then the voltage, then replace it if nessesary.
Old Oct 19, 2008 | 04:41 PM
R RUPERTUS's Avatar
R RUPERTUS
tks ...but it was just replaced ...
Old Oct 20, 2008 | 07:30 PM
F22's Avatar
F22
Good thing you pulled the codes, but do you have a Factory Service Manual? Can't tell you how incredibly helpful they are. The step-by-step breakdown on the troubleshooting is well worth the dough you might spend pulling out your hair!
To Idle problem. ...HELP please
