Transmission Knocking?!!
Old Oct 18, 2008 | 09:14 PM
Rob10R's Avatar
Rob10R
Default Transmission Knocking?!!
Hey guys I got an '95 LT1 w/ Auto Trans w/ bout 120K on tach...The Trans shifts with no problem thru every gear and no knocking noise while driving..I only feel the knocking by my right leg when I'm turning while taking off normally..Anyone?
Old Oct 18, 2008 | 10:41 PM
DanZ51's Avatar
DanZ51
I had a truck with a 700R that started clunking/rattling alot until the torque converter went into lock-up. 'Replaced the converter - no more noise.
Old Oct 18, 2008 | 11:52 PM
Rob10R's Avatar
Rob10R
been thinking to get a better stall converter anyways..maybe this will be my winter project to replace the converter and rear diff gear upgrade as well...the Transmission shifts smooth like it should..when at the hard acceleration theres no knocking..accelerates just fine..I always notice the knocking only when turning right or left and pushing on the gas pedal while moving..feel like I'm hitting the ground or something..
Old Oct 19, 2008 | 02:35 AM
frenchyoliver's Avatar
frenchyoliver
not the trans.
Check the bearings or u-joints
Old Oct 19, 2008 | 10:23 AM
Iroc57's Avatar
Iroc57
Originally Posted by frenchyoliver
not the trans.
It may not be the trans based upon your description. It could be as simple as a broken exhaust hanger
Old Oct 19, 2008 | 10:43 AM
Rob10R's Avatar
Rob10R
yeah I'm gonna do some inspecting when I get a chance to jack the car up...About 3-4 months ago I installed the whole chamberred exhaust system..prior to the install one of the studs on the driver side is broken off holding the manifold and the Cat together..only 2 studs are holding now..I will get new Headers and new cats to replace the stock parts pretty soon..
Old Oct 19, 2008 | 10:58 AM
formul89's Avatar
formul89
Transmissions do not "knock". The torque converter might if the bolts are loose or missing. Most knocks from under the car are either exhaust pipes banging or u-joints.
Full chambered exhaust? Damn, that has to pretty loud!!
Old Oct 19, 2008 | 11:18 AM
Rob10R's Avatar
Rob10R
when I drive it manually in 2nd gear or in D it has a bad a#$ deep rumble sound to it!!
it sounds like I'm going 200 mph already!!
http://www.youtube.com/watch?v=nnx36I3QIUY
To Transmission Knocking?!!
