First fuel injection
A TPI type intake will never make those numbers based on the design. The question should be are u happy with the way it performs on the street or strip? What heads and cam are u using? Are u running out of pull or is it just the numbers that ur dissatisfied with? Me, I don't need no steenkin numbers!!
Tom
Box Stock FIRST Injections intake - Best run in 80 degree temps 5800/5600 shift point. 3.23 gears & 26x11.5 ET Streets.
60ft------ 1/8 ET -----MPH ------ 1/4 ET ----- MPH
1.707 --- 7.992 ----- 85.526 --- 12.599 --- 106.702
The power band for this FIRST intake was about perfect for this combination (355 with 3.23 gears). It didn't feel like the car was dropping off in power up to 6000 rpm, but the ETs showed the car liked to be shifted at 5800 out of 1st (5600 rpm shift caused spinning into 2nd) and at 5600 coming out of 2nd gear. Porting the runners to 1.8 - 1.82" would improve on the time and mph.
STEALTHRAM - Best run in 80 degree temps 6400/6200 shift points. 3.23 gears & 26x11.5 ET Streets.
1.803 --- 8.133 ----- 86.37 ---- 12.673 --- 107.84
That StealthRam rolled off a lot of bottom end compared to the fully ported stock base and SLP runners. This FIRST unit isn't as violent as the ported stock base / SLP combination off idle, but it is a VERY happy medium between the two systems.
If I never raced the car, I'd stuck with the ported stock base and SLP runners (12.90s around 105mph),, super fun
If I raced the car more than I drove it on the street,, the HSR is hard to beat and near impossible to mess up a launch with enough heat in the tires. It was also easier to manage on the street.
However,,, while the FIRST was a little tricky to launch on the track and the street, it was just more fun to drive around. Much more midrange throttle response.
I had dynoed the HSR and it made 330RWHP at 5850RPM. I would estimate the FIRST wpuld have dynoed around 315RWHP but at a much lower 5300rpm based on the 5800/5600 rpm shift points.
With the my next mods I fully expect to exceed 400rwhp.
