96 C4: HVAC Temperture Control
Old Oct 21, 2008 | 10:01 PM
foosman5's Avatar
foosman5
4th Gear
Default 96 C4: HVAC Temperture Control
I have a 96, and the heater temperature control only seems to blow hot air at 85 - 90 digital settings. It's like all or none, and it can not be controlled at the lower temperture. Blower fan works fine.
I would have thought the vent door motor malfunction, but in does go hot and cold. It just does not seem there is any control between.
Any ideas?
Old Oct 21, 2008 | 10:11 PM
foosman5's Avatar
foosman5
4th Gear
Oh, and I have no fault codes other than a catalytic convertor.
Old Oct 22, 2008 | 02:17 PM
IRAraid's Avatar
IRAraid
Default HVAC Hot control
My Dad had an electronic controlled A/C Buick with your symptoms. It was the outside air temperature sensor. On your Corvette it's located on the passenger side and low/front of the radiator. Actually a thermistor. They do go bad and sometimes get disconnected.
Good luck and hope this helps.
Old Oct 24, 2008 | 06:28 PM
foosman5's Avatar
foosman5
4th Gear
Thank IRAraid,
I will research it. I bought this car for my daughter 7 years ago. When she gets back in town ,I will check it out.
Old Oct 24, 2008 | 07:38 PM
formul89's Avatar
formul89
Originally Posted by foosman5
Thank IRAraid,
Wow, nice father!!
To 96 C4: HVAC Temperture Control
