Adhesive for lowering wedges
Old Oct 23, 2008 | 11:25 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Default Adhesive for lowering wedges
What type of adhesive would be best for keeping the lowering wedges attached to the spring? And, where can I buy it? Any suggestions on what to do during the curing to make a stronger bond?
I used some Loctite brand 2-part epoxy from Lowe's that was supposed to be compatible with plastic when I first did the lowering. I noticed recently that the drivers side wedge has come loose and moved. I have not seen the passenger side but it it probably hosed as well.
Old Oct 23, 2008 | 11:34 AM
LTxDave's Avatar
LTxDave
I used weatherstrip adhesive and glued it to the frame--no problems in about 8 years of use. I'd be careful of using chemicals on a composite spring.
Old Oct 23, 2008 | 11:44 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I suppose gluing the wedge to the frame is an option.
All of the posts I've read have the wedge being glued to the spring unless I misunderstood.
Old Oct 23, 2008 | 11:50 AM
reoch999's Avatar
reoch999
Oops, when I read this I thought it said "lowering wages." That's a whole different issue, so my reply would be off topic. My bad.
Old Oct 23, 2008 | 12:50 PM
85corvettekws's Avatar
85corvettekws
Kind of off-topic, and I'm sorry for this, but how much does it effectively lower the car?
Old Oct 23, 2008 | 12:56 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
5/8ths... maybe 3/4 on the front. It has settled some since I originally did the mod. I don't have any of the measurements I took before lowering. It does not have a slammed look. More lowering is possible by removing/modding other parts of the front suspension but I was only looking for a little drop.
Old Oct 23, 2008 | 03:36 PM
StealthLT4's Avatar
StealthLT4
I used 2-part high-strength epoxy from Advance Auto. Going on something like 10 months now with no problems. Glued to the spring.
To Adhesive for lowering wedges
