94 Heater Temperature Door
Very recently I've noticed that (1) A/C isn't blowing ICE COLD (System Charge is good) and (2) Heat isn't blowing HOT as it has in the past (seems luke warm).
I suspect the Temperature Door is not operating based on some data I collected from the Head Unit (in diagnostics mode). The format is:
(Temp Setting), (Temp Door Position Request), (Temp Door Travel Range) obtained from the diagnostics locations 1, 34, and 31 respectively.
60, 253, 162
65, 173, 162
75, 76, 162
80, 49, 162
86, 17, 162
90, 0, 162
The data suggests that the head unit is commanding a particular door position and that the door is not moving. It looks as if the Temp Door is stuck near mid range (100 <= Range <= 200).
I collected this data this morning and have not had a chance to read over the FSM.
Has anyone had a problem with this on a 94 and how difficult is the cure? I've read where it's a major PITA for 93 and earlier models but simpler for the 94 and beyond.
[My Bad, just found related post http://forums.corvetteforum.com/show....php?t=2164739. However I'm searching for info specific to the '94.]
Drop the RH hush panel and see if the control rod is still attached to the motor arm and then see if the motor tries to move the arm when you switch between 90deg & 60deg on the control panel.
Also there's an error in my OP: The diagnostic register that indicates door position is #24 and it is following the commanded value indicated in #34.
Guess it's possibly time to flush the heater core? I need to look for a differential in temp between heater core inlet and outlet hoses. Inlet is supposed to be warmer than the outlet, which makes sense.
