Broadcast code
Old Oct 28, 2008 | 01:10 AM
Movnviolation's Avatar
Movnviolation
Default Broadcast code
I am going to order a chip from TPIS and they ask for a broadcast code.
Anyone know what that is?
Old Oct 28, 2008 | 02:14 AM
rodj's Avatar
rodj
What car / trans ?
Codes are unique to a certain year / trans combination.
Is printed on the memcal inside the ECM
http://chevythunder.com/prom_bcc_1989.htm
Old Oct 28, 2008 | 02:19 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Codes for the 89.
http://www.chevythunder.com/prom_bcc_1989.htm
Old Oct 28, 2008 | 02:31 AM
WVZR-1's Avatar
WVZR-1
Try your VIN here and check the results. I do believe it will give the correct "original/as built" information and include any "rolling" updates.
http://tis2web.service.gm.com/tis2web
Old Oct 28, 2008 | 03:00 AM
Movnviolation
Thanks to all. I have a copy of the build sheet. Will this have any info?
Old Oct 28, 2008 | 07:41 AM
rodj's Avatar
rodj
I don't believe the code is on the build sheet / nor is it referenced from the VIN as there is no reference in the VIN for trans type.
What year model and trans do you have?
Old Oct 28, 2008 | 11:05 PM
Movnviolation
89, six spd.
Old Oct 29, 2008 | 12:41 AM
rodj's Avatar
rodj
Originally Posted by movnviolation
89, six spd.
apyp
Old Oct 29, 2008 | 01:09 AM
Movnviolation
apyp
Old Oct 29, 2008 | 01:22 AM
rodj's Avatar
rodj
Originally Posted by Movnviolation
APYP is the broadcast code for a '89 6 spd with 3.45 gears
Old Oct 29, 2008 | 01:28 AM
Movnviolation
Great, thank you so much!
Old Oct 29, 2008 | 01:54 AM
WVZR-1's Avatar
WVZR-1
Did you try the link I provided for you to enter the VIN? I've used this for calibration information and PROM ID's for years and I used it yesterday for some '90 and '91 information. It worked for them!
BTW no 3.45 in '89 MY either 3.33 or 3.54 but "rodjs" info is good both axle ratios I'm quite sure. I did though see some other information in a parts catalog for an ANYL I believe but both used the same service replacement PROM. I'm interested in what information the link provided.
Old Oct 29, 2008 | 03:13 AM
rodj's Avatar
rodj
Originally Posted by WVZR-1
BTW no 3.45 in '89 MY either 3.33 or 3.54 ... I'm interested in what information the link provided.
My oops.
I tried my '87 VIN and nothing came up.
Old Oct 29, 2008 | 10:14 AM
WVZR-1's Avatar
WVZR-1
My oops.
Here's an '87 MY VIN from eBay: 1G1YY3186H5124850 You can use this to see how it works. You need to use some avalable information but you'll see all the possibel combinations to match specific RPO's etc. We used this information in OBD1 days to arrive at the "more current" available updates for the PROM. It surprises me that it would do one '87 VIN and NOT another. Is yours an EXPORT specific build?
To Broadcast code
