Which wheel is installed wrong?
Old Oct 28, 2008 | 07:27 PM
car5car's Avatar
car5car
Default Which wheel is installed wrong?
Old Oct 28, 2008 | 08:23 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
The front, But I don't like those wheels anyway.
Old Oct 28, 2008 | 08:31 PM
danno85's Avatar
danno85
The rear is wrong - it's a "left side" wheel.
Old Oct 28, 2008 | 08:39 PM
engle1147's Avatar
engle1147
Got this pic of google images.....there are a truck load of photos of corvette photos with wheel shots....most show the same rotational directional pattern as this car.
Old Oct 28, 2008 | 08:52 PM
Road Agent's Avatar
Road Agent
Who cares what you like!
Old Oct 28, 2008 | 09:01 PM
Joe C's Avatar
Joe C
Old Oct 28, 2008 | 10:42 PM
car5car's Avatar
car5car
They are all wrong!!! (i think)
This way decreases rotor ventilation. And it looks bad.
Old Oct 28, 2008 | 11:03 PM
engle1147's Avatar
engle1147
Your OP question was "which wheel is installed wrong?" Here is a corvette brochure with more wheel shots. The wheels may vent better with them flipped....how you choose to mount them is up to you....if your running directional tires make sure they are mounted in the correct direction for your final positioning.
Good Luck!
Old Oct 29, 2008 | 12:02 AM
zbo2's Avatar
zbo2
looks like an 86 rim on the back and a 85 on the front.....i'm partial to the 86's myself....lol
gotta go with the brochure for the correct rotation.
Old Oct 29, 2008 | 12:08 AM
ßill's Avatar
ßill
Aren't they stamped on the inside (RS or LS) mine (different year) are.
Old Oct 29, 2008 | 12:14 AM
MK 82's Avatar
MK 82
Yes
Old Oct 29, 2008 | 01:12 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default wheels
YAY! BILL wins the prize. take your wheels off, and they will give you the proper locations as cast in the wheel.
Old Oct 29, 2008 | 08:05 AM
danno85's Avatar
danno85
The fins in these particular wheels are not designed to facilitate venting. They are designed to draw air in, to the inside of the wheel, to aid in brake cooling. And yes, the wheels are marked on the inside either "left side only" or "right side only".
Dan
Last edited by danno85; Oct 29, 2008 at 08:10 AM. Reason: to correct my spelling :)
Old Oct 29, 2008 | 10:09 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Dan
For track use I run my wheels in the "wrong" direction for two reasons. 1) I want to draw air out of, not into, the wheel well area. I don't want the wheelwell/undercar area to be at any higher pressure than I can avoid.
2) Under hard braking, the fins are then under compression, not tension. Not a big deal, but my preference.
Old Oct 29, 2008 | 11:44 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
ORLY
To Which wheel is installed wrong?
