MAP and IAC install on 1992
Old Oct 29, 2008 | 07:51 AM
Randy Munson's Avatar
Randy Munson
Default MAP and IAC install on 1992
Hello to all. I was wondering if the install of a Manifold Absolute Pressure(MAP) sensor and the install of a Idle Air Control (IAC) valve was a straightforward process with each? It looks very simple. Two screws, gently pull up, and remove for the MAP, and unhook harness, put wrench on IAC and turn out. Are there any adjustments for either of these that needs to be made. If so, I'm heading to my Chevy dealer and paying the $100/hr for them to install. I thought someone once said something about the IAC had to have the "pintle"(?) adjusted to the same distance as the old one. Huh? I just installed a new shocks(KYBs), EGR, coil, and ICM, so I'm not a total dufuss, but I also want to do this right. I know, I know, buy the service manuals!!!! Many, many thanks to all. I'd be totally lost without these forums. Maybe someday I can contribute when someone else has a question(like how difficult it can be getting that lower power steering pump bracket bolt on when putting in a new coil and ICM!).
Old Oct 29, 2008 | 08:15 AM
engle1147's Avatar
engle1147
Do a search for ICA adjustment.....or visit CF member Vader's site. He has a pretty good write up on the IAC install adjustment. I'm not sure if if there is any difference between a '92 IAC and his '89 but like you said this is where the year specific FSM (Field Service Manual ~ $140 new) would be helpful. I did see a used set of FSM for a 92 for sale posted in the C4 Parts For Sale/Wanted section.
Old Oct 29, 2008 | 11:25 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I'll look in my FSM tonight for the IAC adjustment.
MAP is deffinately remove two screws, disconnect from vaccum line, connect new to vaccum line, screw down tight the two screws.
Old Oct 29, 2008 | 11:37 AM
Randy Munson
Thanks a million! I sure appreciate your help with adjusting my new IAC! What a great place this(as I stated earlier)!!!!!
Old Oct 29, 2008 | 01:41 PM
cfi's Avatar
cfi
I second all of the above. Buy a FSM, I got mine on ebay AND go to Vaders site. His is very useful and informative easily understood
Old Oct 29, 2008 | 01:42 PM
aklim's Avatar
aklim
I would think that just using a scantool to set the IAC so that the counts are about 15-20 would be fine. Works for me.
To MAP and IAC install on 1992
