90 Tuned Port Idle Problem
Old Oct 30, 2008 | 11:09 AM
Tripleblack90's Avatar
Tripleblack90
Default 90 Tuned Port Idle Problem
I have a 1990 L98 6-speed that I am having problems getting it to idle correctly.
-Replaced TPS
-Replaced Throttle Body (reman)
-Replaced IAC
With the throttle cables unhooked, the car will idle fine, if you slowly rev the car up and let it down slowly it hangs up at 1300 RPM. If you blip the throttle and let it come back quickly, the car will idle back down.
The throttle body is brand new and works freely, the cables are unhooked, I tried it again without the TPS and IAC hooked up and it did the same thing.
It seems as though the vacuum will hold the throttle plate open (barely)unless you flip it quick and then it will idle back down.
Getting ready for a bon-fire after pulling all my hair out
Old Oct 30, 2008 | 11:20 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You've got to have something hanging up in the throttle body. Either the blades or the shaft somehow. Rev it up slowly, let off it slowly, then with it idling high just press the lever closed and observe the movement. It might take a few times to actually find it. Once you observe the movement then you can shut the engine off it will be a bit easier to spot with the engine off. One other thing, when the tb was rebuilt, did they put either bearings or bushings on the throttle shaft? If not then you may have a worn casting which is allowing the throttle blades to be sucked open a bit while the rpms are up. If this is the case then send it back to them with a jar of vaseline and instructions on what to do with it.
Old Oct 30, 2008 | 12:24 PM
rons85's Avatar
rons85
Double check the attachment/mounting of the TPS to the TB. I've seen replacement TPS's that have enough of a protruding screw, or rivet, holding the lever arm on that the protrusion gets jammed into the end of the Shaft sticking out of the TB when you tighten the TPS mounting screws down.
You would Think that since both the TPS and the TB shaft are rotating together it wouldn't matter, but it Will cause the stickiness you describe. If that's your problem then Careful grinding of the TPS screw, or the end of the TB shaft, to get clearance there will fix it. Or a washer under each of the TPS mounting tabs...
Also look carefully to make sure that the TPS arm/lever isn't rubbing on the TB housing and sticking - not following the shaft back down to idle. I've seen That happen as well. You said it does the same thing with the TPS disconnected, so likely not the case here, but check it anyhow..
Old Oct 30, 2008 | 01:14 PM
rick lambert's Avatar
rick lambert
I'd even suggest you check the gas pedal itself, get it to where it revs and then reach down and pull back on the pedal, sometimes it's just that easy.
Old Oct 30, 2008 | 04:34 PM
Tripleblack90
I will check this out
Old Oct 30, 2008 | 04:35 PM
Tripleblack90
The throttle cables are not hooked up when this is happening, when it does rev high you can manually push the butterfly closed and the problem goes away.
Old Oct 30, 2008 | 04:43 PM
the blur's Avatar
the blur
I once brought a TB from AS&M that was defective.
it had an intermittent high idle .
tossed it in the junk heap, after AS&M wasn't too helpful.
Old Nov 2, 2008 | 02:15 PM
Tripleblack90
I removed the TB and everything operates freely. When mounted on the car without the cables hooked up it operates freely. When you start the car, the vacuum seems to bind up the throttle plate. While it was off, I tried putting tension on the shaft every way possible and it still worked fine. The minute you start the car, the throttle will not return to idle on its own unless you blip it hard. I add another spring to help it close. It helped a little but the problem is still there.
Old Nov 2, 2008 | 07:59 PM
Tripleblack90
ttt
Old Nov 9, 2008 | 05:33 PM
Tripleblack90
Originally Posted by Tripleblack90
ttt
ttt
Old Nov 9, 2008 | 05:51 PM
engle1147's Avatar
engle1147
I had the same problem a number of years ago here's my fix.....I've been running it for years with no problems. I installed an extra spring (acordion style spring....it is painted black and hard to see) to keep the TB shut at idle.....it adds a little extra postive feel to the pedal as well.
Old Nov 10, 2008 | 09:09 AM
Tripleblack90
I put the helper spring on it already. It made a slight difference. I can't believe how freely this operates with no cables on it and the minute you start it up without the cables, the vacuum won't let it idle down unless you flip the throttle plate really quick.
BTW---No codes.
Old Nov 10, 2008 | 09:20 AM
engle1147's Avatar
engle1147
BTW---No codes.
Yes, my TB has 250k miles on it so i can't complain. The comment about returning the thing to whom ever sent/sold it to is right on the money. That's just bad business they need to make it right.
Good Luck!
Old Nov 10, 2008 | 01:15 PM
Tripleblack90
Good Luck!
Bought it off E-Bay from xtreme-fi
Now he doesn't return e-mails.
To 90 Tuned Port Idle Problem
