'89 C4 Plenum hose line connections.
Old Oct 31, 2008 | 04:56 PM
Ripps's Avatar
Ripps
Default '89 C4 Plenum hose line connections.
I am trying to piece this back together... I can't figure out what attaches to the center [CORRECTION] bottom connection at the front end of the of the plenum on the passenger side.
The recommendations from below suggest that this is a hose line from the firewall near the heater core... is this correct?
Old Oct 31, 2008 | 06:04 PM
Damien89's Avatar
Damien89
A pic would be better for us to help you.
Old Oct 31, 2008 | 06:24 PM
janarvae's Avatar
janarvae
On my '91 L98 there are 3 ports at the REAR passenger side of the plenum. I don't have any at the front passenger or driver's side. I don't think GM would have changed the plenums that much in 2 years, or did they?
If you do mean the rear, I can get a picture for you.
Old Oct 31, 2008 | 09:51 PM
DINO84's Avatar
DINO84
Does this help?89 6spd.
Old Oct 31, 2008 | 10:40 PM
rodj's Avatar
rodj
Originally Posted by Ripps;1567680526..
what attaches to the center connection at the front end of the of the plenum at on the passenger side.
Assuming you are talking about the TB ;
Top is to pass side rocker cover
center is vac pipe to drv side front wheel well
bottom is water hose
Old Nov 1, 2008 | 12:10 AM
Sam Lam's Avatar
Sam Lam
I have a 89 auto trannie car. Let me know if you need photos
Old Nov 1, 2008 | 08:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Nov 1, 2008 | 06:10 PM
DINO84's Avatar
DINO84
I believe it is correct.I think it warms the incoming air in cold weather.My cars not hear but I CAN CHECK IT OUT ON MONDAY.
Old Nov 1, 2008 | 08:32 PM
AGENT 86's Avatar
AGENT 86
The bottom nipple is for coolant from heater core line. It enters TB there, and exits at front TB nipple, which goes to nipple at front of intake base.
Old Nov 1, 2008 | 08:37 PM
bczee's Avatar
bczee
That is the hose that comes from the heater.. it connects into the TB as to warm and heat the TB.. you can bypass (known as T/B bypass free mod). On the front of the T/B, there should be aport that connect to the intake maniold.
Old Nov 2, 2008 | 10:55 AM
Ripps's Avatar
Ripps
Default Thanks!!
Ok, that takes care of it... I've got it back together now!!
Thanks Again!!
To '89 C4 Plenum hose line connections.
