Can't remove clutch slave
I have a blown clutch slave seal and was able to buy a slave unit, but I can't get the stock one of the Hyd line.
The replacement Bendix unit is threaded but I cant wrench the stock one off. I'm using a 1/2" F\\flare end wrench, turning CCW, but it won't budge at all.
I thought, until I found the slave only, that the master/slave and Hyd line, factory stock were one piece. Is it possible that the stock nut doesn't thread out of the fitting?
Any tricks to getting it out?
Evan
