Help with oil leak?
Old Nov 1, 2008 | 09:27 PM
pt's Avatar
pt
Default Help with oil leak?
My car is leaking right behind the water pump/ optic spark/ pulley. I place my hand right under the optic spark and it came out full of oil. Has anyone had this problem? I know is coming from that thing right behind the optic ( I forgot the name of it ) Does any one know what kind of gasket or gaskets I need to buy in order to fix the leak. Any other gastket in theat area that I should change since Im taking out almost everthing infront of the engine?
Old Nov 1, 2008 | 09:55 PM
aminnich's Avatar
aminnich
Front cover seals for the w/p, opti, and front mail seal. Of course you will need new w/p gaskets as well. You sure it is not the front of the intake leaking?
Old Nov 1, 2008 | 11:50 PM
pt's Avatar
pt
Default gasket
Not sure if is the front of the intake leaking. I have to check tomorrow. I look with a flash light and most of the oil seems to be coming from the bottom right under the optic. Is it easy to change the seal of the intake?
Old Nov 2, 2008 | 12:24 AM
pianoguy's Avatar
pianoguy
If you discover that it is the intake, double check to see if the bolts are torqued to spec. Mine was leaking a bit from the front and rear of the intake, and I found that the bolts on both ends were not tight. I tightened them all to spec and it hasn't leaked a drop in over 5000 miles.
Old Nov 2, 2008 | 12:26 AM
pt's Avatar
pt
Default gasket
Good point, I will check the bolts. Now If I need the seals, were can I get them. I've check eckler's and I only see the seals up to 1991.
Old Nov 2, 2008 | 08:42 AM
aboatguy's Avatar
aboatguy
Make a call to your local autopart stores
any of the big chains stores should be able to get them for you (autozone pep boys NAPA advanced auto O Reilly etc)
Old Nov 2, 2008 | 09:04 AM
pianoguy's Avatar
pianoguy
Here's a great thread on seal replacement, but unfortunately a lot of the pictures have disappeared:
https://www.impalasuperstore.com/nai...TOPIC_ID=30984
And a thread on replacing the intake gaskets:
http://forums.corvetteforum.com/show....php?t=2033363
I have seen these guys mentioned as a source for the front cover seals - I would imagine they're available from the dealer, too:
http://www.daltonbearing.com/Supplie...FQ0GQAodzkrFqw
To Help with oil leak?
