Afr spack plug application
Old Nov 2, 2008 | 07:49 PM
twin540's Avatar
twin540
Default Afr spack plug application
ok ,I just installed a set of afr 195. What do any of you afr owner recommend for spark plugs? I'm having trouble finding the right plug.. one is to short or to fat please help..
Old Nov 2, 2008 | 09:24 PM
John A. Marker's Avatar
John A. Marker
I have the AFR 180's, but the documentation that came from AFR with these heads recommends AC FR3LS or Champion RC9YC for street application. Be sure to use antiseize on the threads.
Old Nov 3, 2008 | 11:40 AM
aklim's Avatar
aklim
I am using NGKs. Champion seems fine in lawnmowers but not much else.
Old Nov 3, 2008 | 01:11 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
We need to update that info....a "9" is colder than most need unless there was alot of boost or nitrous involved. An RC12YC or evan a "14" if its conservative on the CR with no nitrous (less than 10 to 1) would be fine.
Nothing wrong with the Champs btw....ran an RC12YC in my 610 HP 383 LS street engine (11 to 1 CR) with perfect results. With the price of plugs these days you can throw away alot of money needlessly....if the Champs are cheaper (as they usually are), go for it.
Hope this helps...
Thanks,
Tony
Old Nov 3, 2008 | 03:22 PM
89FX3's Avatar
89FX3
ACDelco 41-629.
To Afr spack plug application
