Wheel offset for 86 vette
Old Nov 3, 2008 | 08:56 PM
86C4VETTE's Avatar
86C4VETTE
Default Wheel offset for 86 vette
Guys what is the correct offset for a 86 vette? To mount a later style ZR1 11" wheel on the rear of a 86, what would be needed. Just trying to research what I currently have on my car. Purchased with ZR1's mounted already.
Old Nov 3, 2008 | 09:05 PM
LKoncar's Avatar
LKoncar
The 11" rim should be 36mm
Old Nov 5, 2008 | 09:01 AM
cwyates4's Avatar
cwyates4
unless it was 56 mm and has spacers. how do the wheels fit in the fender well, pretty flush to the outside lip?
Old Nov 5, 2008 | 11:01 AM
c4cruiser's Avatar
c4cruiser
You can use the OEM ZR_1 wheel that has a 36mm offset. There are companies that sell ZR-1 style 11" wide wheels that will fit the 84-87 cars.
Keep in mind that the 315/35-17 tires used on these 11" ZR-1 wheels are not that easy to find. The basic tire choices are cheap or really expensive. You might get a pair of tirs now, but 3 years from now, that size may be very difficult to find.
Old Nov 5, 2008 | 03:11 PM
vader86's Avatar
vader86
A true ZR1 rear rim goes on without anything needed. A Grand Sport rear rim does not.
And as has been said, you might want to buy up a few sets of tires.
Fronts in 9.5" need a 38mm offset.
Old Nov 20, 2008 | 07:45 PM
phillip goff's Avatar
phillip goff
go to factory repoductions in chino,calf or their on e bay
Old Nov 21, 2008 | 12:58 PM
slickfx3's Avatar
slickfx3
http://www.joby.se/corvette/div/corvette_wheels/
http://www.joby.se/corvette/div/vetteinfo.htm
Home
1984-1996 Corvette Wheels 1984 (base)
front & rear 15"x7" 17mm
Goodyear Eagle GT, P215/65R-15
These wheels were in the catalouge, but were never installed on any new Corvette.
1984 (base)
front & rear 16"x8.5" 32mm
Goodyear Eagle VR50, P255/50VR-16
1984 (z51)
front 16"x8.5" 32mm
rear 16"x9.5" 38mm (6.7" backspacing)
1985 (base)
1985 (z51)
front & rear 16"x9.5" 38mm (6.7" backspacing)
black painted centers
1986 (base)
1986 (z51)
aluminum centers
1987 (base)
1987 (z51,z52)
grey painted centers
1988 (base)
front & rear 16"x8.5" 50mm
1988-1989 Callaway (b2k)
1988 35th Anniversary Edition
front & rear 17"x9.5" 56mm (7.4" backspacing)
Goodyear Eagle ZR, P275/40ZR-17
White Wheels
1988 (z51,z52)
1989 (all)
1989 (pre production zr1)
front 17"x9.5" 56mm (7.4" backspacing)
Goodyear Gatorbacks, P275/40ZR-17
rear 17"x11" 36mm (7.93" backspacing)
Goodyear Gatorbacks, P315/35ZR-17
1990 (base)
1990 (zr1)
1991 (base)
Goodyear Eagle ???, P275/40ZR-17
1992 (base)
Goodyear Eagle GSC, P275/40ZR-17
"SAWBLADES" with cast surface
1991 (zr1)
1992 (zr1)
Goodyear Eagle GSC, P315/35ZR-17
1993-1996 (base)
front 17"x8.5" 56mm
Goodyear Eagle GSC, P255/45ZR-17
Goodyear Eagle GSC, P285/40ZR-17
1993-1995 (z07)
1996 (z51)
"SAWBLADES" with machined surface
1993 (zr1)
1994-1995 (zr1)
1995 pace car
P275/40ZR-17 B/W Tires
1996 Collectors Edition (base)
front 17"x8.5" 56mm
1996 Collectors Edition (z51)
1996 Grand Sport (coupé)
rear 17"x11" 50mm (7.93" backspacing)
1996 Grand Sport (convert.)
front 17"x8.5" 56mm
Goodyear Eagle GSC, P255/40ZR-17
Additional information
Link to a 1984-1996 Corvette Suspension Chart
All 1984-1996 Corvette wheels have 5 bolts and the bolt circle diameter is 4.75"
To use 1988-1996 wheels on a 1984-1987 Corvette you need 0.75" spacers.
The 11" wide rear zr1 wheels will fit 1984-1987 Corvettes without spacers.
The 1984 and 1985 wheels were made from an aluminum casting that do not shine much when polished.
Enkei produced the 1986 and 1987 wheels for GM and they were made of an aluminum that could be polished to a high luster. These Enkei produced wheels also were slightly larger on the inside, which means you can use the '88 and later 2-piston front brake caliper with a 13" rotor. The Enkei produced wheel can be identified by a small symbol in one of the slotted radial wheel vents which looks like an "m" grafted to an upside down "J".
Tire Size Calculator
Use the calculator to see what happens to your speedometer reading when you change the size of your tires and wheels. The graphic shows your stock tire selection in an outline overlaid on your new tire selection.
To Wheel offset for 86 vette
