C beam ?
Old Nov 4, 2008 | 07:06 PM
pipe's Avatar
pipe
Default C beam ?
Will the C Beam from my D44 manual shift car bolt right up to the 700R i'm going to drop in it? Or will I need to shorten or make it longer? THANKS Pipe
Old Nov 4, 2008 | 07:35 PM
janarvae's Avatar
janarvae
I was incorrect in assuming the OP was changing diffs too.....refer to post below.
Old Nov 4, 2008 | 07:40 PM
danno85's Avatar
danno85
If you are staying with the D44, it will work just fine with either the ZF6 or 700r4. The D44 has a longer snout than the D36 and that is when you need to change the driveline support.
Old Nov 5, 2008 | 07:00 PM
pipe's Avatar
pipe
The 700R is going in my 88 the car originally was a 4+3 So will it still bolt right up? Pipe
Old Nov 5, 2008 | 07:49 PM
WVZR-1's Avatar
WVZR-1
I don't know much about the 4+3 but if it was/is a 27 spline output shaft you "might" be able to use the driveshaft "as is" without a slip-yoke change.
I'm curious! Is the 4+3 a 27 spline unit?
Old Nov 5, 2008 | 07:52 PM
danno85's Avatar
danno85
Yes, the transmissions are the same length - the same driveline support will bolt up if you are not swapping the differential.
Old Nov 5, 2008 | 08:12 PM
WVZR-1's Avatar
WVZR-1
I thought this question related to the "complete install" rather than just the C-beam! Sorry!
Still curious is the +3 a 27 spline unit and were you able to just use the driveshaft "as is"?
Old Nov 5, 2008 | 08:28 PM
rodj's Avatar
rodj
Originally Posted by WVZR-1
is the 4+3 a 27 spline unit and were you able to just use the driveshaft "as is"?
Yes
For some reason the stock auto yoke has a big balancer on it but I used the 4+3 shaft with my auto swap ; no probs.
27 spline yoke is common across GM products with
alum Glide / TH350 /T700/most manuals ,ex ZF6 which used 40 spline T400 yoke.
Old Nov 5, 2008 | 08:59 PM
WVZR-1's Avatar
WVZR-1
The ZF, TH400 and 4L80E are a 32 spline unit! An "exception" was what was called a TH375, really a TH400 with a 27 spline used in some "lighter duty" trucks.
I assumed the +3 was a 27 spline unit but "needed" to ask!
Old Nov 6, 2008 | 02:20 AM
rodj's Avatar
rodj
My oops , was thinking about 9" axles at the time
To C beam ?
