headlights/temp reading
Old Nov 6, 2008 | 03:24 AM
headaches's Avatar
headaches
Default headlights/temp reading
Good morning
I have a 1985 with a few minor issues the first being the headlights do not close.I have the upgraded system with the isolation module and i was wondering if the module may be bad.I am hoping some one can give me some advice as how to check this out as the module is quite expensive.My other question is my coolant temp always reads low i never get a reading and i have replaced the temp sender for both the gauge and the ecm as well as the fan switch. thank you for any advice you may be able to provide.the car has an auto trans if that has any impact
