take ft spring out to lower
Old Nov 5, 2008 | 01:52 PM
tomracer69's Avatar
tomracer69
Default take ft spring out to lower
hi,just lowered my 95 with longer rear bolts .car sits perfect for me in the rear .now to do the front ,i bought the wedges to lower 1inch . my question is do i have to take the spring compltey out of the car to do this? or can it be done with spring in car.if so i looks like a bitch of job to do in my garage . any thoughts on this . thanks tommy nyc
Old Nov 5, 2008 | 07:27 PM
BAM92's Avatar
BAM92
It is a very involved job but not too hard. You have to be able to take off the pads on top of the spring to bond the new ones on. Then you have to cut down the brackets that held the spring to match the amount of size difference between old wedges and new wedges. I am not sure how you would do that while spring is still in car. Do a search as to other posts so you have an idea what all you have to do and some peoples short cuts.
Old Nov 5, 2008 | 08:21 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/show....php?t=1989887
To take ft spring out to lower
