Hot bodied corvette....
Old Nov 6, 2008 | 06:07 PM
Vetster88's Avatar
Vetster88
Default Hot bodied corvette....
I was hooking up my new battery with a disconnect.
While hooking it up, with the disconnect disengaged, the wrench bumped my side fender and SPARKS FLEW! So I grabbed my test light and off I went testing grounds. How do I find out where the short is located? Or am I over reacting to a completion of a circuit?
Anyone have with Ideas please respond!
Thank you,
~Dane
Old Nov 6, 2008 | 07:30 PM
AKS Racing's Avatar
AKS Racing
You are over-reacting to the completion of a circuit...
Old Nov 6, 2008 | 07:45 PM
Vetster88's Avatar
Vetster88
Default Thanks :)
That makes me feel better!
I was hoping there was an actual short tho, because when I accelerate agressively from a stop or cruising it hick-ups and bogs the more throttle it gets more it wants to choke. I'm going to make a spur of the moment call and say it's the fuel pump. I had 2 fuel pump problems before I started an over-haul of the interior. Zero psi, both times until my mom would come out and make a comment then it would fire right off... the first time took 9 hours, before starting and running at 45 psi.
To Hot bodied corvette....
