Rear Wheel Bearing Damage and Alignment
in a moment of stupidity i slid my C4 backwards (driverside rear hitting first) over a short curb at about 10 MPH. after the fact i just simply can't bring the camber back into alignment. its not out by much about .75 degrees from where i would like it but it am at the limits of the strut rod cam. when i drive it when the drive side rear bearing "howels" a bit and gets worse in a right hand corner, seeming to be a tell tale sign of a bad bearing.
My question is does anyone think that a bearing (especially one that was stressed in the way mine was) could cause the camber to be so hard to bring back into spec?
perhaps the rear bushing on the strut rod was damaged? but is sure seems like its ok.
thanks in advance guys!
Are you able to get the rear toe setting correct? If the alignment is being set based upon the premise of all components being straight, but something is bent, the car is tracking down the road incorrectly.
Check the strut rod carefully to ensure that it is true. If it's even the slightest bit tweaked, replace it. Then get the car back up on the alignment rack and see how things shake out. I really can't see a wheel bearing disallowing a camber setting....unless it is seriously distorted...and I doubt the car would even be driveable in that case. But...I've been wrong before.
If it were my car, I'd take the whole rear suspension apart on that side and start checking every component. Yes, I've had one apart before, and no, it's not fun. Check all your bushings while it's down, make sure nothing is mushy or worn.
Good luck to you....and don't beat yourself up for hurting the car....we've all been there before.
this is the one that i found that seems like a nice one:
http://www.mamotorworks.com/corvette-3-148-1089.html
i also think i am going to replace the strut rods anyway here is what i found but i am open to suggestions: http://www.mamotorworks.com/corvette-3-157-1139.html
the howl is not the kind that you would get with tire scrubbing (i did not describe that well at all), so i am going to do both bearings.
as for the toe, the funny / strange thing is its dead on from where i had it, i sure expected everything to be hosed up.
But I still think something is bent...most likely the strut rod. The sudden inability to get a decent camber setting is what's leading me there. I don't think the bearing is causing that. Good time to meausure everything while you're doing bushings.
Incidentally, poly bushings will REALLY wake up the way the car handles.
while i was at it i bought a Polyurethane bushing kit on all four corners, for the $200 ish i paid for the it, it is WELL worth the money, its better than ever in terms of handling!!
the only gripe I had was getting the new strut rods installed, they where a pain, has anyone else had this problem?
thanks guys for all the support and suggestions!
with the suggestions above. Also look at the carrier's(batwing) ears to make sure they are not bent or damaged.
