What AN fitting = 7/16?
Old Nov 8, 2008 | 07:49 PM
armybyrd's Avatar
armybyrd
Default What AN fitting = 7/16?
Would it be -4? Just wanted to make sure before I ordered the fittings.
Old Nov 8, 2008 | 10:08 PM
MK 82's Avatar
MK 82
It's a -7. They are numbered in 1/16s.
Old Nov 8, 2008 | 10:34 PM
armybyrd's Avatar
armybyrd
This is for my vortech fmu. the supernatural kit said it was -6 but that is too big and Summit doesnt carry -7.
Old Nov 9, 2008 | 08:24 AM
mseven's Avatar
mseven
that's probably because a -7 doesn't exist......or at least I've never heard or seen anything but even sizes -4, -6, -8, -10, -12, -16,-20.
what is 7/16" AN being used for, and if so, are you sure it is not a NPT ?
Old Nov 9, 2008 | 08:51 AM
Joe C's Avatar
Joe C
http://www.gre6.com/ansize
Old Nov 9, 2008 | 09:10 AM
Pete K's Avatar
Pete K
If the fitting takes a 7/16 wrench, then it is a -4
Old Nov 9, 2008 | 11:19 AM
AKS Racing's Avatar
AKS Racing
FMUs are typically set-up with a 1/4" NPT fitting into and out, except the larger "race" FMUs whigh use a 3/8" NPT. If it has the 1/4" NPT threads, then you should use the 1/4" NPT x -6AN fittings to adapt to the fuel sytem.
Aaron
To What AN fitting = 7/16?
