Derale 700R4 cooling pan...
Old Nov 9, 2008 | 10:21 AM
Iroc57's Avatar
Iroc57
Default Derale 700R4 cooling pan...
I am having trouble with my fluid heating up and causing the TC to slip. I am changing to synthetic, wrapping the headers and exhaust by the pan.
My question is...Has anyone used the deep Derale pan with the cooling tubes in it? If so did you see a difference?
I hate to spend $80 on a pan with no net gain
Old Nov 9, 2008 | 10:25 AM
_twisted_'s Avatar
_twisted_
I have one, it is a nice pan - as long as you're moving the cooling passages will work, also you increase the amount of fluid in the pan with it.
I can't give you a direct answer because I have a derale cooler and fan plus a dewitts rad
Old Nov 9, 2008 | 10:29 AM
Pete K's Avatar
Pete K
I like the pan. Quality piece, fair price.
It wall add approx 20% more fluid capacity, and this will help most.
Option b (for budget) would be to buy a $25 (shipped) deep chrome pan off ebay. This would probably be the better value, but buying the Derale would be my recommendation.
Old Nov 9, 2008 | 10:30 AM
Iroc57's Avatar
Iroc57
Holy crap...your trans must be chillin'
Old Nov 9, 2008 | 10:44 AM
_twisted_'s Avatar
_twisted_
Ask PeteK - I don't f... around
you can't have the fluid to cool, heat killz
Old Nov 9, 2008 | 10:51 AM
Iroc57's Avatar
Iroc57
The budget was out the window when I started but I just don't want to throw good money after bad. You know your 700s so I will go with your recommendation
Old Nov 9, 2008 | 11:19 AM
toptechx6's Avatar
toptechx6
Try sending a PM to Weav's Vet, pretty sure he has a Derale pan he may deal on.
Old Nov 9, 2008 | 11:21 AM
engle1147's Avatar
engle1147
[QUOTE=Iroc57;1567784082]I am having trouble with my fluid heating up and causing the TC to slip. I am changing to synthetic, wrapping the headers and exhaust by the pan.
QUOTE]
The thermal exaust wrap will help with slowing down the heat transfer....I used the stuff on a number of close quarter applications on several cars and I'm running it on my '89 now, just the way you describe. Be aware that the area you wrap will rust and rot over time. Doesn't matter if its regular steel, ceramic coated steel, or stainless steel(depending on the grade)it will rust/rot. Use SS hose clamps to secure the end of each wrap run.
Last edited by engle1147; Nov 9, 2008 at 11:22 AM. Reason: there is an "h" in thermal
Old Nov 9, 2008 | 12:16 PM
Iroc57's Avatar
Iroc57
[QUOTE=engle1147;1567784659]
QUOTE]
I expect some rust but this isn't exactly a daily driver so I probably won't have it by the time it does
To Derale 700R4 cooling pan...
