stall/stumble
Old Nov 9, 2008 | 07:55 PM
Adam/WOT's Avatar
Adam/WOT
Cruising
Default stall/stumble
Really need some help here guys.
My 86 died a month ago. Wouldn't crank at all-finally found out it was the 5 amp fuse behind the info center in the dash...replaced it and it cranks and ildes fine. BUT pulling out of the drive it stumbles when I hit the gas like I am use too. If I let off it will smooth a bit and then if I slowly get into the gas it will do its best to maintain speed. I have already tried everything ie.. new fuel pump, new fuel filter, noid light on the injector harness. My Sunpro fuel pressure gauge says the pump starts (ignition on) about 20#s and maintains with the car cranked a little above 30#s is this normal??
What should the pressure be?
One more thing not to be a pain but when I check the aldl via jumping it I was getting some codes but I cannot figure how to decypher them. How do you get 12 from 1 flash pause 2 flashes long pause and so on. I got (after the handshake) 4 flashes pause 3 flashes (what code is that and how do I count it???)
Old Nov 9, 2008 | 08:22 PM
engle1147's Avatar
engle1147
Did a quick search for you:
http://forums.corvetteforum.com/c4-t...code-43-a.html
Your fuel pressure seems way low..either you gage is bad or ...fuel pressure regulator or pulsator module may have issues.....do a search for fuel pressure tests.
Old Nov 9, 2008 | 08:27 PM
Adam/WOT's Avatar
Adam/WOT
Cruising
I really really appreciate the reply, how do you figure out which code it is by the flashes?? I am so lost my wife has 2 degrees in comp programming and neither one of us can figure out how you get the numbers by the flashes. Any help??
Old Nov 9, 2008 | 08:33 PM
engle1147's Avatar
engle1147
I have a computer I hook up to the car to read my codes...it also give you real time values for each sensor's reading.
If I remember right the after the hand shake you get a one or series of flashes then a pause, this it the first digit. Then you get another single or series of flashes (1-9) this is the second digit. Then you should get another pause and the next code will show if you have others......etc
Your '86 has a OBD1 computer in it.......Walmart sells code readers for cheap.....but make sure you get a reader that does OBD1. Most for sale now a days are for OBD2...some do both. There is all kinds of software/freeware out there that you can download onto a laptop to read your cars codes.....but you'll need an interface cable for it to work.
Old Nov 9, 2008 | 08:37 PM
UNCLEBILL's Avatar
UNCLEBILL
On my 1990 when checking codes...code 12 will flash(meaning all is okay if no bad codes)---1 long--2 short..this will happen 3 times in sequence.If there is a bad code after the 3 flashes of 12 the fault code will flash(e.g. 42) 4 long---2 short and will repeat 3 times. If no other bad codes; then will finish with 3 times code 12 flash to close the communications.
Old Nov 9, 2008 | 08:44 PM
whalepirot's Avatar
whalepirot
Memory says it should be about 40psi with the vacuum hose disconnected. Vacuum will drop the pressure, so you can test the ops of the FP reg with a vacuum pump, while reading the pressure change with your gauge.
Adam/WOT's Avatar
Adam/WOT
Cruising
I have a computer its just at my work and didnt feel like going for it today wanted to learn it the roots way. Thanks so much for the explain on the codes that really does help I kept tellin my buddy I thought it was the Mass air flow sensor or I had bad gas. Would the knock sensor be sending that code if I had crappy arab gas?? The car ran fine when I filled up the last time before hurricane Ike and then I filled up afterwards at a BP next to the house we just bought and my truck and the vette and my scout have been acting up. Will that do it to your knowledge??
Old Nov 9, 2008 | 08:45 PM
engle1147's Avatar
engle1147
Thanks Bill!
Old Nov 9, 2008 | 09:00 PM
engle1147's Avatar
engle1147
I think you should focus on the fuel pressure issue I think it should be ~43-44 with the vacuum line disconnected....i'm surprised it runs at all if the pressure is that low. If you suspect bad gas siphon it out of there and get some fresh stuff in there. Use suspect gas in lawn mowers and pressure washers stuff like that.
Old Nov 9, 2008 | 09:08 PM
Adam/WOT's Avatar
Adam/WOT
Cruising
K im gonna bug you one last time the vaccum line your speaking of is it on the regulator?
Old Nov 9, 2008 | 09:19 PM
engle1147's Avatar
engle1147
Yes sir here is a pic of the Fuel Pressure Regulator's location(this is an adjustable FPR the pic....your stock one will be black and ugly and most likely covered in dirt)......this is not my pic and the vacuum lines are not installed in a OEM fashion where the hose connects is line you should remove during pressure testing/reading.
Old Nov 9, 2008 | 09:33 PM
Adam/WOT's Avatar
Adam/WOT
Cruising
Engle sir you are officially my new bestest friend, lemme know when your birthday is and i send ya some of my (Lowndes County) famous hot sauce. thank you so for all your help if I can figure this dang site out I'll add ya as a friend and help you anyway I can I'm a recent Ford convert so I'm stumblin a little just like the ole car I have fell in love with.
Old Nov 9, 2008 | 09:38 PM
Adam/WOT's Avatar
Adam/WOT
Cruising
Default pressure
well I did unplug the vaccum line on the regulator and I'm still at 20#s with the key on and 30#s with the engine running when I give it some gas the guage drops a pound or two. Could this be the regulator or an injector?? Still searchin. Thank you guys for helpin and suggestin its really getting my brain movin towards the cure
Old Nov 9, 2008 | 10:15 PM
engle1147's Avatar
engle1147
The search tab on the colum row of this page is your friend...click search then type in what your trying to find. Again - seems like a fuel pulsator or fuel regulator problem to me. Keep us posted with what you find. Most all the guys here on this forum are great and very helpful. But in the end this is your car so only what you want to do. It might be helpful to pick up a FSM Factory Service Manual for your year car...they run about $130 new but sometimes there is a used set for sale in the C4 parts section for much less.
Old Nov 9, 2008 | 10:28 PM
Adam/WOT's Avatar
Adam/WOT
Cruising
thanks again gonna sleep on this one, I scratched my head for a month on the non starting issue and got that one nailed down so I refuse surrender. I know it is going to be something terribly simple And after 30 years die hard Ford man I will not quit on my lil chevy.
Old Nov 10, 2008 | 04:22 AM
vette079's Avatar
vette079
No change after the new fuel pump?
What brand fuel pump, bought where?
If fuel pump ok, then it´s probably FPR.
If you really have a code 43, it says electronic spark control.
Check the wiring on the whole distribution system.
Old Nov 13, 2008 | 10:48 PM
Adam/WOT's Avatar
Adam/WOT
Cruising
well its a cheapo fuel pump i bought from AutoZone, I honestly do not believe it is the pump I'm leaning more towards the regulator as Engle suggested havent had the chance since sunday to research more. Thank you guys for all the help I'm gonna get back on it. I think both of you are on the money though and the regulator is my enemy. Should I go with an OEM type or buy an adjustable as I am planning on mods as soon as she gets back on the road healthy have already restored the interior and other items and wouldnt mind a little extra GO.
Thanks again to all
a
Old Nov 13, 2008 | 11:13 PM
engle1147's Avatar
engle1147
Thanks again to all
a
The autozone part might be OK. The fuel pulsator module fits right above the pump cost ~$20 would have been easy to change it out when you did the pump. As far as goin' with the Adjustable Fuel Pressure Regulator (AFPR) it depends on what you want to do with the car. A AFPR will allow you to crank up rail/injector pressure incrementally....you'll appreciate it if you plan on future mods. AFPR kits usually do not include the regulator diaphram, it is only the housing that you buy ~ $60 and up. Fuel pressure regulator diaphrams run ~ $45 up. I'd run the fuel pressure tests first before you start swaping parts out.
Old Nov 15, 2008 | 12:37 PM
wb2dyb's Avatar
wb2dyb
Default Code 43
Its actually real, real obvious...code 43, which translates to ESC (knock sensors) which means that on terminal B-7 of the computer should be 6 volts iff all's ok. Probably need to check the wires for short, or sensors for short. The pressure...is shown in the Haynes book as 34-39 PSI. and deliver 1/2 pint or more in 15 seconds.
GeorgeC
To stall/stumble
