Question--Roller Lifters
Old Nov 17, 2008 | 03:25 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default Question--Roller Lifters
On the roller lifters in my LT4, there is a pin hole on one side of them. There were facing front and rear and before I re-install them,
Which way the pin hole should face?
Rear, front or the same way they came out?
Old Nov 17, 2008 | 03:41 PM
STL94LT1's Avatar
STL94LT1
From everything that I've read, it doesn't matter. My originals were in no certain position.
Old Nov 17, 2008 | 06:51 PM
rklessdriver's Avatar
rklessdriver
It really does not matter as long as you have oil pressure, but...
If possible I always face oil supply hole on roller lifters to the rear of the block, as oil comes up to the cam/lifters via the main oil galley (which is in the rear of the block), intersects the cam and lifter galleys and then once in the lifter galleys travels from rear to front in a SBC.
Installed this way you put the lifters oil supply hole in the direct path of oil pressure.
Will
Old Nov 17, 2008 | 08:49 PM
Calderone's Avatar
Calderone
i agree,did the same
Old Nov 18, 2008 | 12:39 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Will
Thanks, this makes sense!
To Question--Roller Lifters
