L E 2-- Heads and Intake (Pictures)
Old Nov 17, 2008 | 04:08 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default L E 2-- Heads and Intake (Pictures)
Received the LE2 package from Elliot Portworks last Friday. I'd say Santa showed up early.
Heads, intake and cam (blue card). I do not remember who recommended me Elliot but, THANK YOU He has outstanding customer service, answered all my questions and provided me with all part numbers to complete my project.
Old Nov 17, 2008 | 04:31 PM
mnstrlt1's Avatar
mnstrlt1
awesome parts, I can't believe you're doing all that without pulling the engine out of the engine bay. Did you have to lift the engine up at all to remove the cam?
Old Nov 17, 2008 | 04:41 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Do you have the flow numbers to the heads?
Old Nov 17, 2008 | 04:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
Looks like youre well on your way to getting it back together again. I do not envy your job of changing a cam in a C4.
Ill leave the next question to our Canuck friend.
Old Nov 17, 2008 | 04:50 PM
STL94LT1's Avatar
STL94LT1
Looks like a strong combination!!
Old Nov 17, 2008 | 04:53 PM
1989TransAm's Avatar
1989TransAm
I wonder if the intake cam specs are correct on the card. It has .050" at 223 degrees. Then the .006" specs are 288. That is a difference of 65 degrees. That is quite abit in this day and age. Maybe it should read 278@.006"?
Old Nov 17, 2008 | 05:30 PM
bobmic93's Avatar
bobmic93
I thought the hot cam was 218/228? Either way it should be a lot more powerfull then current set up.
Old Nov 17, 2008 | 06:11 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Cool!!!
How bout a pic of the intake ports from the topside?
Old Nov 17, 2008 | 06:22 PM
JimiHendrix's Avatar
JimiHendrix
Were new valves guides installed, or were the old ones reamed out to fit the larger valves?
Old Nov 17, 2008 | 07:15 PM
95wht6spd's Avatar
95wht6spd
Nice, you will like it, I like my LE2 setup.
Old Nov 17, 2008 | 09:40 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nice work
Be sure to post some #'s when your done!
Old Nov 18, 2008 | 06:22 AM
88BlackZ-51's Avatar
88BlackZ-51
I will pass!
Old Nov 18, 2008 | 08:14 AM
NightTrain66's Avatar
NightTrain66
No need to change guides or seats when going to a 2.02/1.60 in LT4 heads. Just re machine the setas and they are fine.
That is not a HOT CAM, it is a cam that will pass emissions as easily but make more power though.
The intake lobe on the cam card is rated at .004 duration (seat timing) and the exhaust lobe is listed at a more common .006 duration.
With both measured at .006 duration, it is 276/281 (same as CC 503 cam).
The lift on the cam card is measured with a 1.5 rocker. A 1.6 rocker brings the lift to .565/.565.
The blue dye on intake rocker bosses is to show what studs need sealant used on threads.
Lloyd
Old Nov 18, 2008 | 12:56 PM
1989TransAm
"The intake lobe on the cam card is rated at .004 duration"
Ok, that makes more sense. Nice set of parts which should do you well.
Old Nov 19, 2008 | 02:03 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Originally Posted by GREGGPENN
Cool!!!
As you wish...
Old Nov 19, 2008 | 04:28 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Nice work Lloyd!!
I love my LE2 setup. Its running great and the power up top is really incredible compared to the factory LT-1
LE2 porting for your LT4 should be hot!!!
Old Nov 19, 2008 | 04:51 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Down the road, once I get most of this project off, my LT1 is next.
Old Nov 20, 2008 | 10:55 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Dumb question- is there any writeup on how to do a H/C swap on C4's? I'm --->this<--- close to pulling the trigger, but I want to make sure I know WTF I'm doing.
I assume I have to remove:
Radiator, PS rack, and everything on the front of the motor. I already have a EWP, an ATI damper, and a new(ish) opti. Anything else that should be replaced "while I'm in there"? Oil pump and timing chain?
Is there a trick to keeping the lifters from dropping?
What about tuning? Every shop I call doesn't have LT1 edit.
Old Nov 20, 2008 | 12:08 PM
STL94LT1's Avatar
STL94LT1
Here's a great writeup on a camshaft install.
http://www.hashmarks.com/techtips/hot_cam.htm
To L E 2-- Heads and Intake (Pictures)
