Changing a fuel pump in a 84
Its not necessary to drain the tank but its a good idea to do so, for safety's sake.
Step one: have the parts on hand PLUS 3 ft of 3/8" fuel line and 1 ft of 5/16" fuel line. I know, you may not need the fuel line, but in many cases it's faster and easier to remove the old line and replace with new ones.
Hose clamps: you'll want several 1/2" size for the lines
Fuel pump
http://www.ecklers.com/product.asp?p...dept%5Fid=1277
Fuel pump screen
http://www.ecklers.com/product.asp?p...8&dept_id=1277
fuel filter
http://www.ecklers.com/product.asp?p...9&dept_id=1303 (optional but a GREAT IDEA)
Ok, step one:
Make darn sure the keys are out of the car and the battery is disconnected for extra safety!
Step two: open the fuel fill door center rear deck where you normally fill the car and remove the gas cap
Step three: remove the four very small Torx screws in the corners and lift off the door assembly
Step four: There's a rubber bib fuel spill tray (around the fill spout). Remove the gas cap and work the bib fuel spill tray out, then disconnect the water drain line and label it with masking tape and a pen.
Step five: Label the three lines with masking tape/pen (upper line, lower line, and left side line). Remove each at the central point in the opening, then disconnect the electrical connector on the lower edge of the opening
Step six: remove the eight 10mm bolts and look carefully where the components go. After they are removed, the pump lifts up and out (the pump normally comes with instructions) that are fairly simple to follow.
The pump, fuel lines, and fuel level sensor lifts out as a sub-assembly, look through the link below for pictures and more info.
NOW IF YOU WANT TO UPGRADE, HERE'S A MORE USEFUL LINK WITH PART NUMBERS
http://www.caspeed.com/boschpump/boschpump.html
