quick help please 1987
Old Nov 18, 2008 | 08:05 PM
mjb1019's Avatar
mjb1019
Default quick help please 1987
Can someone tell me how to get the black air filter holder off the car?
I am changing the fan motor all is well but when I turn the black thumb *****, they just seem to turn. Not the air filter cover, the compartment that holds it. I didn't know if there was a secret to getting it off
Old Nov 18, 2008 | 08:08 PM
tankman's Avatar
tankman
On mine they simply unscrew.Maybe someone king konged yours on!
Old Nov 18, 2008 | 08:11 PM
mjb1019's Avatar
mjb1019
they spin but seem to not be coming loose
Old Nov 18, 2008 | 08:14 PM
pologreen1's Avatar
pologreen1
they are long keep going or else they are stripped! I doubt it I bet it is not on right! you just sit back relax think it over and then attempt again it will come off simple!
Old Nov 18, 2008 | 09:25 PM
Empire2's Avatar
Empire2
they are clipped on one end. try pulling up while turning. Dont tighten them too tight when putting them back. Also if you pull the entire housing left to right it will come off. That is for extreme measures only
Old Nov 19, 2008 | 05:34 AM
covertte's Avatar
covertte
Yes, keep upward pressure under plastic ****
When you finally get them off you will see the problem
After several struggles. I replaced the plastic with stamdard metal wing nuts...no problems
For some reason, plastic binds on treads and the whole assembly is a little suspect
Old Nov 19, 2008 | 06:09 AM
1irishprince's Avatar
1irishprince
I kept havving this problem as well. I finally wound up putting a couple of 1/8 inch pop rivits from the little metal tabs to the upper radiator shroud andd then used some grease on the threads. Problem fixed!
Old Nov 19, 2008 | 08:39 AM
WW7's Avatar
WW7
Irishprince definitly has the answer on how to fix it,this was my fix also,but to get it off slide a pair of needlenose pliers under the plastic intake and grab the bolt with them and hold it while you turn the plastic **** with the other hand,should come right off, mine did...WW
To quick help please 1987
