Jerking/bucking
Old Nov 21, 2008 | 12:25 PM
tankman's Avatar
tankman
Default Jerking/bucking
Good afternoon,
When driving at less than 45 MPH and until the 'Vette (1987) warms up,the car bucks and jerks.After warm up and at faster speeds it runs smooth and fast.I have changed plugs,wires,coil,cap,rotor,O2 sensor,& air filter.There are no codes,and SES light is not on.
I have an FSM,but don't know what to look for.Have any of you with 87's experienced this issue? If so please give me your thoughts.Thanks in advance.
tankman
Old Nov 21, 2008 | 01:03 PM
Master__Shake_'s Avatar
Master__Shake_
When you say "warms up", what temp do you mean? 110, 120, 130, 150? Usually, atleast on a cold day, you should wait until it warms up to a good 120-130 before a cruise.
If it's stumbling when over 130 then it may be a problem with the injectors, even though it doesn't happen when hot. It may also be the fuel pump and/or filter.
I hope you find out what's wrong.
Old Nov 21, 2008 | 01:18 PM
rick lambert's Avatar
rick lambert
Time for a fuel pressure test, ohm the injectors, hot/cold, possibly CSI. IAC, carboned up. After checking fuel pressure and ohming injectors I'd run a can of SeaFoam throught it. I typically put a half can in the tank ans suck the other half through the brake booster vac. line. Just make sure if you do to follow the rest of the instructions.
Old Nov 21, 2008 | 01:25 PM
engle1147's Avatar
engle1147
Check that fuel pressure regulator (FPR) too....with a bleed down test or pull the small vacuum hose off the FPR and see if gas shoots out...if it does its bad.
Old Nov 21, 2008 | 01:36 PM
tankman's Avatar
tankman
Okay.Thanks to all three of you guys.I didn't know I should have waited until the eng.warmed to 120-130 ,I'll start doing that.Then I'll proceed with the other advice you all have offered.
Thank you very much .
To Jerking/bucking
