We have recently purchased our dream car. 1988 Corvette coupe with 68,000 original miles. We know absolutely nothing at this point, but will learn! Our engine temp runs at about 215-235 all the time. This is ok or too high? Read some threads where they suggested changing the sensor to turn the fan on at a certain temp. Can anyone explain this to us?
The temp your describing sounds normal for a stock set. You may want to pick up a FSM (Factory Service Manual) for your year vette. You may not need it now but you will eventually if you hang onto the car. New reprinted FSM run about $130 +tax+shipping. Sometimes you can find good "used" FSM set in the C4 Parts for sale section for cheap.
Your temps seem ok for stop and go driving but a little high for highway driving. My '89 coupe runs about 185-195 at 60+mph this time of year where the outside temps are around 65-70 degrees.
Factory service manuals are a must! additional tools you'll want to pickup are a digital voltage ohm meter and a fuel pressure guage.
As far as the temps go, I think there a little high for this time of the year! 2 things, check between the radiator and condensor for debris, these cars suck up everything! And read the tech tips, there is a write in there on how to do you rfans, I did mine and I'm very happy, my 87 never gets over 205 in stop and go summer months.
