ZF6 Misc Torque Specs
Old Jan 14, 2002 | 11:11 PM
tommelton's Avatar
tommelton
Default ZF6 Misc Torque Specs
I am installing a ZF6 in my 86, and being that it is not factory, the info I need is not in the 86 shop manual.
Can someone look up the following torque specs and forward them to me please?
Flywheel to Crankshaft
Clutch Cover to Flywheel
Bellhousing to Block
Transmission to Bellhousing
Torque Arm to Transmission
Ft/Lbs would be appreciated.
Thanks in advance...
Tom Melton
82 CE
86 Z51 Coupe
Old Jan 15, 2002 | 04:33 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: ZF6 Misc Torque Specs (tommelton)
Flywheel to Crankshaft - use 86 specs or (94 is 74) use loctite for bolts
Clutch Cover to Flywheel - 30
Bellhousing to Block - 37
Transmission to Bellhousing - 37
Torque Arm to Transmission - 37
all in ft lbs
Don't forget the goop for the torque arm to keep moisture out. I used RTV silicon for mine.
Old Jan 15, 2002 | 06:26 AM
tommelton's Avatar
tommelton
Default Re: ZF6 Misc Torque Specs (AquaMetallic94LT1)
Aqua...
Thanks much.
-Tom
To ZF6 Misc Torque Specs
