84 starting issues
First check to make sure that when you replaced all the wires you put them back in the correct firing order.
Your sure that you installed the coil correctly,rotor and put the cap back on?
Do you have the connections to the coil correct? they are pushed in and making good contact.
When you turn the key to the on position do you hear the fuel pump turn on? You should here it for a couple of seconds.
When I did mine the first time I knock the wire connector off the fuel pump relay and it wouldn't start. I thought I had all kinds of fuel problems then found that.
Maybe you knock the wire connector off the oil sender?
These are all easy things to check before you start thinking that you got these major problems.
Good luck.
If you hear the pump running when you run 12V to terminal G, then you need to test the pressure...which, by the way, takes some effort on an 84. You will need a low pressure (0-15 psi) gauge. You can run a T fitting (clamped) on the pressure line right past the fuel filter and attach the gauge there. You should have between 9-13 psi or the car won't run.
And if terminal G causes it to run, but key on and cranking past 4 psi doesn't....test both the relay and oil pressure switch on the one in a million shot both have failed. If they check out, time to trace some circuitry.
Won't make a lick of difference, and certainly won't cause a no-start condition. The oil pressure switch acts as a backup to the relay. Should the relay fail, it will energize the pump when pressure reaches approx 4 psi during cranking. If the relay is functional, the oil pressure switch never comes into play. Both the relay and the oil pressure switch would have to be bad or disabled for this to happen, which is very unlikely. And the terminal G test will rule that out anyway.
I've said this a million times, so one more won't hurt....TROUBLESHOOT, DON'T GUESS.....and don't throw parts and money at a problem to fix it unless you are independently wealthy and have all the time in the world...which I'm betting you don't
OK, when you say "got fuel when I jumped it" what exactly do you mean? Did you visually see the injectors spraying? By "jumped it" do you mean running 12v to terminal G?
OK, if the relay isn't energizing, do you have 12 volts at the relay at key on? The ECM should energize the relay for 2 seconds at key on, and then voltage should drop to 0 unless the car is being cranked.
Need to know this stuff before we can go further.
If you weren't 1800 miles away we'd have it running in an afternoon....would cost you a pizza and 2 six packs of Fat Tire.
Keep the car long enough and do your own wrenching and you will be that expert at some point.
Pick up a cheap fuel pressure gauge and run a T from the pressure line to the gauge (remember to clamp it), energize terminal G, and tell me what you see on the gauge.
