1985 Corvette Cold start Injector
Old Dec 3, 2008 | 10:10 PM
cherokeecorvette's Avatar
cherokeecorvette
Default 1985 Corvette Cold start Injector
Im trying to find my Cold start injector on my 85 vette to test and c if it is bad, Can any1 explain in detail were it is or have a diagram?????
Old Dec 3, 2008 | 10:39 PM
Droshki's Avatar
Droshki
Left side of the intake, between the intake runner tubes. If you cant find it Ill go out and shoot you a picture, but if you look right in the middle of the left side, between the tubes, you will see it. Coincidently, it will have wiring running to it from the same harness that feeds all the other injectors.
Should be obvious now that you know where to look.
Old Dec 3, 2008 | 11:44 PM
John A. Marker's Avatar
John A. Marker
To make it a little clearer left side is the drivers side. You should also see a small steel line running from the rear of the drivers side fuel rail to the 9th injector.
If you had to, it can be removed (also have to plug the drivers side fuel rail at the rear) and plug the injector hole with a plate.
Old Dec 4, 2008 | 08:10 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Fu...l%20System.pdf
http://members.shaw.ca/corvette86/Co...rt%20Valve.pdf
Old Dec 5, 2008 | 08:36 PM
cherokeecorvette
I found the cold start injector un pluged it and now in process of taking it out and testing it.
To 1985 Corvette Cold start Injector
