O2 sensor location
Old Nov 23, 2008 | 01:01 PM
ragged claws's Avatar
ragged claws
Default O2 sensor location
Anyone have a photo or accurate diagram showing the location of the one oxygen sensor on an '89 coupe? Is there a bung in the front Y pipe or, as the FSM suggests, does it screw into the exhaust manifold? I've looked through the exhaust system section of the FSM and can't find a drawing that shows its exact location. I ordered a front Y pipe from Mid-America but don't know if it needs to be tapped for the sensor. A picture will be worth a thousand words to me at this point.
Thanks, Kim
Old Nov 23, 2008 | 01:32 PM
Aardwolf's Avatar
Aardwolf
It's in the exhaust pipe below the manifold. If you look down under the wiper motor area you can actually see the sensor. Look for a purple wire sticking out of a round shiny sensor. What is the link for what you ordered? I'll look at it. I would highly doubt MAM would send a Y pipe without the O2 bung.
