MAF screen removal
Old Jan 15, 2002 | 09:36 AM
jims_red_94LT1's Avatar
jims_red_94LT1
Default MAF screen removal
Can someone let me know whats involved/process in removing the MAF screens, and the approximate increase in airflow? Can the screens be re-installed?
Thanks-Jim :flag
Old Jan 15, 2002 | 01:04 PM
dt35th's Avatar
dt35th
Default Re: MAF screen removal (jims_red_94LT1)
i cut mine out with a utility knife, i dont think they can be removed and then replaced with the same ones, sorry dont know air flow
Old Jan 15, 2002 | 01:38 PM
Ed Ut's Avatar
Ed Ut
Easy to remove the screen; on my 96 there was a metal clip in a groove; so remove the clip and them I gently tapped on mine from the backside and it came right out. Be careful not to damage the element. I have done this procedure on three vettes; never any problems.
Old Jan 15, 2002 | 01:45 PM
Rick86's Avatar
Rick86
Default Re: MAF screen removal (dt35th)
If your careful then the screens can be glued back on. The screens are glued to a circular disk, which in turn is glued to the MAF, if you pop off the disk the screens will be unharmed.
Old Jan 15, 2002 | 04:04 PM
GlockLT4's Avatar
GlockLT4
Default Re: MAF screen removal (Rick86)
I pulled the screens on mine pretty easily. I didn't cut them out.. just poked them out from the other side, so I can still put mine back in, just have to be careful when doing so. I don't intend to put them back in though. I've heard there is as much as a 100cfm increase in air flow. That makes the TB the most restricting part of the intake system I believe.
Old Jan 15, 2002 | 04:30 PM
jims_red_94LT1
thanks for the response
Old Jan 15, 2002 | 04:31 PM
jims_red_94LT1
Default Re: MAF screen removal (Ed Ut)
thanks
Old Jan 15, 2002 | 04:32 PM
jims_red_94LT1
thanks
Old Jan 15, 2002 | 04:34 PM
jims_red_94LT1
Default Re: MAF screen removal (Glock'94)
thanks, I guess they are only on one side of the element? if I'm understanding you correctly.
Old Jan 15, 2002 | 04:48 PM
vader86's Avatar
vader86
well i know there are screens on both sides of the element in mine
Old Jan 15, 2002 | 08:51 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: MAF screen removal (vader86)
I don't know if you want to bother with this one. I ran a consistant 14.0 in my stock 97 Trans Am, LT1 auto. At the strip one day I figured I would remove the screens to see if I could get that elusive 13 second quarter mile run. I didn't notice any difference and my track times and mph were identical. I have heard of people getting poorer drivability because the screens help smooth the airflow through the maf. I have never seen anyone gain anything at the track by removing the screens.
If there's no gain and there might be a downside, it might not be worth doing.
Old Jan 15, 2002 | 09:36 PM
Corvette0096's Avatar
Corvette0096
Default Re: MAF screen removal (okinawa86vette)
Here are the numbers you are looking for
529 CFM - max. flow rate stock
711 CFM - max. flow rate with screens removed
750 CFM - max. flow rate with screens and cooling fins removed
Old Jan 15, 2002 | 10:06 PM
JasonL's Avatar
JasonL
Correct, on the LT1 MAF. Note that the L98 MAF is completely different than the LT1 style.
On the LT1 MAF, you can replace the screen/clip as easily as you can remove it...no cutting involved.
[Modified by JasonL, 6:08 PM 1/15/2002]
Old Jan 15, 2002 | 10:55 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: MAF screen removal (JasonL)
It popped out very easily on my '94, and I could see how I could put it back in, but I doubt I will.
Old Jan 15, 2002 | 11:59 PM
GlockLT4's Avatar
GlockLT4
Default Re: MAF screen removal (BAdAzZV8)
Since the screens don't exist in LS1 engines.. i figure GM figured out they aren't needed. And ANYTHING in the intake that takes up space that air could be flowing through is a restriction.
Old Jan 16, 2002 | 12:15 AM
powerslide91's Avatar
powerslide91
I talked with a buddy that worked at a speed shop and has loads of chassis dyno time. He did specific tests to see if removing the screens would help, and at least on the later LT1/4 cars, he saw absolutly no increase on the dyno. This included stock and slightly modded cars, like cut airlids, K&N, TB bypass....
On the earlier cars, the screens are different and do seem to benefit from removing the screens.
Personally, I have left the screens in for now to reduce the chance of damage to the element, but hey, whatever works for you.
Jeff
Old Jan 16, 2002 | 12:24 AM
GlockLT4's Avatar
GlockLT4
Default Re: MAF screen removal (powerslide91)
Jeff
What about a 383 with a HOT cam and other goodies? I would think that it would help open up the inflow of air.. especially with the use of a 52 or 58mm TB
To MAF screen removal
Old Jan 16, 2002 | 12:28 AM
R23HTC's Avatar
R23HTC
I took mine out also. Wouldn't be to hard to put back in if I wanted to. Don't see any reason why though.
Old Jan 16, 2002 | 12:31 AM
powerslide91
Not too sure, since my car is still a ways from that point. I think like some others have pointed out, it doesn't hurt to try it.
Just FYI, he also recommended against going to a larger TB unless you are dealing with a 383+ motor, but even then it is not always needed....
Jeff
Old Jan 16, 2002 | 12:38 AM
Jsailor24's Avatar
Jsailor24
In visiting with a neighbor who is in the local club and gutted his MAF he said that the guest speaker who is a C4 expert said thet the screens arent necessary and the computer system can make up for anything that could change.
