Shorties
Old Nov 26, 2008 | 01:42 AM
JOSH13's Avatar
JOSH13
Default Shorties
Does anybody on here have shorties on their LT1 ? I'm thinking about buying a set of headers and wanting to see what kinds of gains to expect from shorties. Also how much more work for the LTs ?
Old Nov 26, 2008 | 02:19 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Use the search on this. There are lots of threads on shorties. To inform you, there are no direct "bolt ons". All require modifications (ac brackets, oil dipstick, air line)
Old Nov 26, 2008 | 04:18 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
I put shorties (Hookers) on my 94 along with 1.6 rr + LT4 springs. The header install wasn't too bad. I didn't hook the air tubes back up, though.
Still have stock exhaust and now it has just enough growl to it that you can actually hear it from inside the car.
Gains at the track were very good for such simple upgrades.
Stock performance was: 13.75 @ 101mph.
With shorties & 1.6rr: 13.21 @ 106mph.
Old Nov 26, 2008 | 07:42 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You picked up 5mph with shorties??
Old Nov 26, 2008 | 09:41 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
most likely the gains are more from the rocker swap.
Old Nov 26, 2008 | 10:08 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
The stock exhaust is pretty good but the headers look cool
Old Nov 27, 2008 | 08:39 AM
856SPEED's Avatar
856SPEED
Go with LT's if you can...
Old Nov 27, 2008 | 08:47 AM
Road Agent's Avatar
Road Agent
Old Nov 27, 2008 | 10:44 AM
l98tpi's Avatar
l98tpi
Max G’s
Default long tube
look into long tube headers vs shorties
Old Nov 27, 2008 | 11:02 AM
Radioshop's Avatar
Radioshop
Read up, you'll find long tubes to be the way to go. It's not that much more effort to put them in.
Old Nov 27, 2008 | 11:11 AM
TA's Avatar
TA
And perhaps better weather during the second round of testing
Old Nov 27, 2008 | 11:16 AM
PLRX's Avatar
PLRX
2017 C4 of Year
If you are not in California, go w/ long tubes. I had no choice, I HAVE to pass Smog/sniffer
Old Nov 27, 2008 | 04:31 PM
JOSH13's Avatar
JOSH13
I don't mind the emissions I can get around that. It just seems like the room in the engine bay is so tight so I was wondering how much more work it would really be to do LTs. Also I thought the shorties would be a direct fit ?
Old Nov 27, 2008 | 04:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
If you are in CA you will not pass the visual with long tubes if youre called into a Test-Only facility, shorties are your only option.
Old Nov 27, 2008 | 04:37 PM
JOSH13's Avatar
JOSH13
Yeah I'm not really worried about emissions. I'm in Texas and usually have a few buddies to inspect it haha .
Old Nov 27, 2008 | 04:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
PLRX, were you able to drop those in through the top or did you have to remove oi flter, starter, etc through the bottom to get those on.
To Shorties
