'95 dash airbag cover RATTLE FROM HELL
Old Nov 26, 2008 | 10:16 AM
El T1's Avatar
El T1
Default '95 dash airbag cover RATTLE FROM HELL
'95 coupe
So there is finally enough cool weather to run with the windows up, therefore I finally hear the rattle from hell--semi-rattle, semi BUZZ--going on in the dash. I reach over and hold down the airbag cover (RHS of dash), and the rattle disappears.
Anyone had this? And more importantly, can this auditory assault from hell be stopped?
Old Nov 26, 2008 | 10:25 AM
engle1147's Avatar
engle1147
Originally Posted by El T1
'95 coupe
I know it sounds funny but make sure your hood stops are still tight. With the hood closed and locked pull up and down on the corner of the hood closet to the air bag rattle. If you feel a loose bump in the hood adjust the stop up 1/4 turn or so to make better positive contact with the hood...then see if the noise goes away. Or maybe your air bag is just loose.
Old Nov 26, 2008 | 01:06 PM
guido7834's Avatar
guido7834
quote=engle1147;1567984315]I know it sounds funny but make sure your hood stops are still tight. With the hood closed and locked pull up and down on the corner of the hood closet to the air bag rattle. If you feel a loose bump in the hood adjust the stop up 1/4 turn or so to make better positive contact with the hood...then see if the noise goes away. Or maybe your air bag is just loose.
[/quote]
Also, lube the rubber bumper on the stop. Mine sounded like a squeak in the dash.
Old Nov 26, 2008 | 05:44 PM
Red Dwarf's Avatar
Red Dwarf
The last rattle I had in that area was the pass/side vent outlet below the airbag cover. Might look at that also?
To '95 dash airbag cover RATTLE FROM HELL
