starter
Old Nov 26, 2008 | 01:32 PM
richmond1's Avatar
richmond1
4th Gear
Default starter
how diffcult is satrter rplcement on a 87 c4
Old Nov 26, 2008 | 05:29 PM
armybyrd's Avatar
armybyrd
I had to take the starter off on my '88 during my header install-its cake. Just two bolts and a ground wire.
Old Nov 26, 2008 | 05:48 PM
Iroc57's Avatar
Iroc57
A good beginner procedure
Old Nov 26, 2008 | 06:12 PM
JAKE's Avatar
JAKE
My 86 also had a brace from the front of the starter (nose) to the block. The bolt on that one is a little more difficult to access, but not too hard.
I found that replacing it was more difficult since that sucka is HEAVY. The smaller on on my 96 was a LOT easier because it was easier to hold up while starting a bolt.
Jake
Old Nov 26, 2008 | 06:19 PM
Iroc57's Avatar
Iroc57
Jake
hold up a 700R4 falling off the jack
Old Nov 26, 2008 | 09:53 PM
JackDidley's Avatar
JackDidley
If you have an automatic, the book says to remove the cooling lines. I have done it 3 times just squeezing the starter past the lines. Now I have a little starter from a 91. Slips in and out with room to spare.
Old Nov 26, 2008 | 11:37 PM
Edmond's Avatar
Edmond
Only "difficult" part is squeezing it through the lines.
Make sure to pick up a pack of shims just in case. Driving back to the store because you were too cheap to spend a few bucks on a pack of shims really sucks. Ask me how I know...
Old Nov 27, 2008 | 02:23 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Its a good time to upgrade to a newer version sometimes referred to as a mini-starter. (I believe they started in the Vette's in 89.)
Old Nov 27, 2008 | 03:35 AM
reoch999's Avatar
reoch999
Been there, done that. With friends gathered around laughing thinking I'm screwing around. As the old saying goes, it's all fun and games 'til someone gets smashed by a transmission.
Old Nov 27, 2008 | 08:26 AM
madmike's Avatar
madmike
Ive replaced these in the middle of nowhere. Pretty simple procedure. Just disconnect the battery before you do anything or you might see little gold sparks flying!!!
To starter
