Crackling sound from injectors
Old Nov 26, 2008 | 04:07 PM
93stroked's Avatar
93stroked
Default Crackling sound from injectors
Hello I have a 93LT1 I tried to start it today and it fired for 2sec and then died, then the tach started jumping around and I could hear a crackling sound from the injectors, it sounded like electricity and the fans kicked on . does anyone know whats going? I tryed to get any codes but I dont want to leave the ign. on because it sounds like something is frying. thanks for any info...Mike
Old Nov 26, 2008 | 04:14 PM
engle1147's Avatar
engle1147
Man...that doesn't sound good. I say maybe you got a sparkplug wire jumping or grounding to the block making that noise.
Old Nov 26, 2008 | 04:16 PM
93stroked's Avatar
93stroked
The sparkplug wires are brand new, the sound is coming from the fuel injectors.
Old Nov 26, 2008 | 04:22 PM
engle1147's Avatar
engle1147
How new is brand new...did the noise start when you put the new wires on?
wow, wait for some others to chime in.......this problem sounds interesting.
Old Nov 26, 2008 | 04:24 PM
93stroked's Avatar
93stroked
The wires have about 200 miles on them if that. It just started today
Old Nov 26, 2008 | 04:30 PM
engle1147's Avatar
engle1147
Well the reason I ask is that if the new wires were installed too close to a manifold or other hot item/s it would take only a short while to burn through the insulation ~200 miles....and jump the high voltage coil charge to the block....which would explain the weird tach readings, and the untimely ECM/PCM "on" commands. Maybe check the plug wires closely before firing it up again. Or wait 'til dark and pop the hood and watch for a light show when you crank it up.
Old Nov 26, 2008 | 04:35 PM
93stroked's Avatar
93stroked
Im sorry I should have told you the car won't start it fired up for a second or two then died, that's when it started making the crackling sound, just with the ign. turned on.
Old Nov 27, 2008 | 10:38 PM
Calderone's Avatar
Calderone
You have a short somewhere ...if the noise comes from the injectors
i suspect a short in some of the wires that goes there !
remove all of the injector connections ... then turn it on for a little bit (don't start it)
just put the key in ON and see if the noise is still there
Old Nov 28, 2008 | 08:25 AM
engle1147's Avatar
engle1147
To Crackling sound from injectors
