'84 antenna finial removal help
Old Nov 27, 2008 | 08:56 PM
trivette's Avatar
trivette
Default '84 antenna finial removal help
This probably seems like the most basic question, but I need some help. I'm doing the 'antenna fix' on my car and everything is now apart with the exception of removing the antenna finial (top)so the mast can slide out of the tube. I've tried a vise, vise grip, WD-40, etc. but it will not budge. I'm trying to not destroy it in the process as the '84 style finial is unique to the year, I believe, and will be re-used as part of the fix. Any suggestions for this most simple, yet almost embarassing issue?
Old Nov 28, 2008 | 08:38 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have you tried applying heat with a propane torch ??
Old Nov 29, 2008 | 12:02 AM
trivette's Avatar
trivette
The propane torch and a vise did the trick. I just never thought this simple procedure would be such a pain...
Old Nov 29, 2008 | 08:03 AM
AGENT 86's Avatar
AGENT 86
The downside of stainless is galling. 25 years, doesn't help, either !!
Old Nov 29, 2008 | 05:01 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Its easy - first peal back the fender --
Remove antenna
Repaint fender --
And don't forget to fill the hole
To '84 antenna finial removal help
