L-98 Distributor cap options
Old Dec 13, 2008 | 11:33 AM
redrose's Avatar
redrose
Originally Posted by Bad Karma
Mallory has a red
DUI also has their stree/strip version in red.
if color is important, wipe any distrib cap down with "pre-cleano" or similar to remove any oil or mold release agent from manufact, mask off the plug wire terminal tops and any other sensitive areas, blast with any desired ENAMEL "rattle can" other than metallics or aluminum/silver (even some of those are ok, but some ain't)...paint is really just plastic, same as distrib caps, aluminum in metallics/ silver in some formulations will short circ spark..lacquer paints may craze plastic cap surface, bad unless you want "velvet" look
Old Dec 13, 2008 | 03:19 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Mallory has a red screw down cap and rotor kit, part # is 520. I haven't used it, but it's out there. Found them at Summit back when I was looking at which set up I wanted.
http://www.performancedistributors.com/coils.htm
Huh....they said when I looked into buying one of their distributors (which I found one used), that their cap only came in black for the screw-down model....
