Help? Something disconnected?
Old Dec 2, 2008 | 08:30 AM
frannyzvette's Avatar
frannyzvette
Default Help? Something disconnected?
My husband installed a new starter for me yesterday. But, now, when I turn the key,instead of hearing "click", all I hear is ......silence.
Did he forget to hook something up? Battery is fine.
Old Dec 2, 2008 | 08:41 AM
Iroc57's Avatar
Iroc57
It is a pretty good bet that he forgot something, silence is a bad thing when you turn the key
He just needs to go back and check his work, hopefully he didn't drop it down without testing it first.
Old Dec 2, 2008 | 11:00 AM
jmeyer58's Avatar
jmeyer58
He may have forgot the small wires to the solenoid. They cause the plunger to engage the gear and connect the electrical circut for the starter motor (the clicking noise). If it was the larger battery wire, you would hear the clicking.
Hope this helps
Old Dec 2, 2008 | 07:56 PM
frannyzvette
He took the starter out again today and it works fine. Put it back and same thing. I just saw your post about the solenoid, but I think he checked that, but will check again tomorrow in the daylight. Almost reminds me of an alarm system engaging, like shutting everything off. I know I have a Viper on there too, (I didn't install that). But I also know I do not have a bypass on there for that, or at least, don't think I do.
Old Dec 2, 2008 | 08:16 PM
l98tpi's Avatar
l98tpi
Max G’s
Default Starter Issues
If your car is an automatic and your dash lights and interior lights come on, try to put car in "N" Nuetral and start the car. If nothing happens and the dash lights do not go out when key is turned to start, you may have a faulty nuetral safety switch gone bad. I had this happen to me and replaced the starter and still had issue. The way I found out was by placing the shifter in nuetral and slightly moving it back and forth and the car started.
Good Luck
Old Dec 2, 2008 | 08:23 PM
redrose's Avatar
redrose
need a 12v test light hooked between the "little" post on the solenoid and any ground...whenever you turn/hold the key to "start" the test lamp should go full bright...whether it does or doesn't will tell if prob is in solenoid or in the wiring/switch/vats/etc
Old Dec 2, 2008 | 10:05 PM
frannyzvette
Good Luck
6 speed
Old Dec 2, 2008 | 10:12 PM
l98tpi's Avatar
l98tpi
Max G’s
O.K., haven't had the issue with my 6spd, but I do know that you have to have the pedal depressed to floor before it will crank. There is probably a switch that is around the clutch pedal that has to go closed when the clutch is depressed to close the circuit. Hope this will help.
Old Dec 2, 2008 | 10:17 PM
cv67's Avatar
cv67
St. Jude Donor '05
Common for the switch to go bad, many bypass it.
Old Dec 2, 2008 | 10:22 PM
frannyzvette
clutch pedal? I do have to depress to start the car anyway.
Old Dec 2, 2008 | 10:52 PM
JAKE's Avatar
JAKE
If he installed a new starter and solenoid, the solenoid won't have any sign of where a wire had been connected before. So, I suspect he connected the small wire to the wrong post on the solenoid. Your solenoid probably has two small posts, one should be stampted "S".
If memory serves, the small wire should be connected to the "S" terminal.
Unless you turned in the old starter and solenoid as a core, check the old starter to see where the wire was connected. Then compare that post to where the new wire is connected.
Sure, there are other possible causes, but I'd check the installtion first before diving into those as possible causes.
Last time I had a starter problem, on my 96, at times it would crank and start and at other times it was bone-cold dead, nothing when the key was turned. No click, nothing. A new solenoid cured that.
Jake
Old Dec 17, 2008 | 09:21 AM
frannyzvette
Default Need Viper help
Well we think its the dreaded Viper Alarm that the former owner has installed. Anyone know anything about this. The guys here at work won't work on it anymore, too many wires. How do I get this Viper removed, remember, the car won't start.
To Help? Something disconnected?
