Remove MAF sensor??
Old Dec 5, 2008 | 04:58 PM
grinditout's Avatar
grinditout
Default Remove MAF sensor??
Is this a mod? or will it not just throw the computer into a limp mode?
take a look at this link>
http://www.ecklers.com/product.asp?p...LL-_-43145-_-X
Old Dec 5, 2008 | 05:15 PM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Paul,
You are aware that your stock MAF sensor sandwiches between these two halfs once you remove the stock halves with screens from the sensor? I may not have understand your question correctly.I got the impression you might have thought these pieces just replace your MAF.
Rick
After reading the advertisement. It is misleading. It should say "restrictive factory mass air flow housing".The Granatelli has a larger open area on the I.D. than the stock housing.The stock housing has a center divider that is missing on the granatelli housing increasing the open area of the MAF for increased flow.The housing inside diameter itself is not actually any larger at the center MAF sensor location, just flared and contoured open larger on the ends.These are basically the same design as the aftermarket granatelli MAF sensors.
Old Dec 5, 2008 | 10:46 PM
grinditout's Avatar
grinditout
I was confused at first, on this one, for sure.
But now I think I get it.
Now, I just do not understand where the improvement comes into play, if the middle is the same size.
But no you have not misled me, I am just trying to figure this conundrum out.
Old Dec 17, 2008 | 09:03 PM
l98tpi's Avatar
l98tpi
Max G’s
I have a speed density system on my 91 L98, but I would think that this part is not worth the money. My two cents.
Old Jun 25, 2009 | 04:55 PM
matt c6's Avatar
matt c6
so do you think my granteli maf makes any hp diffenrence i have never had a code come on or any problems with it!
Old Jul 2, 2009 | 01:27 PM
DVNCI's Avatar
DVNCI
Doubt it does anything at all.
The MAFs are very, very sensitive and have a specific calibration loaded into the computer. Technically, even very slight changes in airflow (such as a free-flow filter, different piping, etc) should be re-calibrated to get the most out of the system.
To Remove MAF sensor??
