If anyone can help me i have a 1986 Corvette and I just started having trouble with the auto climate control. At first sometimes i get heat sometimes I don't no matter what i have the temp set at it just blows could air and then I try later and sometimes I will get heat. Coolant system temp is all normal. Then today I decided to take the car for a ride and yet again cannot get heat so I tryed turning the temp down to 60 and back up because sometimes this will get me heat again but now its stuck at 60 . is this unit bad and the door in the dash possibly getting stuck? Any help PLEASE>
C4 of Year Winner (appearance mods) 2019
If you're saying the display is stuck at 60, the control is bad. Otherwise, you've likely broken the clip that connects the temp-control-motor to the temp door. It's a plastic clip that only $5 from a dealership.
The temp door arm (and clip) are located on the passenger side near the ECM.
If broken, the temp door with flop from side-to-side. I suspected hard turns were flopping mine around!
It's kinda "sticky" at max cold/hot though. Doesn't always flip that easy.
You might have to remove the hush panel to see it. (Mine is a little easier to see/observe because I'd also removed my breadbox).
I have a 1988 and my control is stauck on 90, where do you get another control and how much does it cost???
I had the same intermittent problem on my 87. Took out the ACC and cleaned it up. Still didn't work, so I bought a used one off of eBay and that works fine, $75. Still have the old unit. I didn't do the re-solder thing yet on the original unit. If the used ACC dies, then I'll try the soldering fix on my original unit.
