D36 Lube?
Old Dec 9, 2008 | 10:24 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Default D36 Lube?
I am getting ready for some PM and want to know what everyone uses for the rear end lube. What is the best way to get the old stuff out?TIA
Old Dec 9, 2008 | 01:30 PM
toptechx6's Avatar
toptechx6
Here are a couple of links to earlier posts, my post #2 links to the commonly accepted method in this first one.
http://forums.corvetteforum.com/c4-t...nd-gasket.html
In this second link, see my post #4 for the method I prefer.
http://forums.corvetteforum.com/c4-t...questions.html
Either method will get it done, I use Mobil 1 synthetic (less than 2 qts required) and 1 tube of friction modifier,(Trans-X brand) some believe in using the genuine GM lubricant and 2 tubes of friction additive. Some brands of synthetic indicate no posi additive is required, I doubt it makes a lot of difference, the function of the additive is to minimize clutch chatter on turns.
Old Dec 9, 2008 | 06:33 PM
engle1147's Avatar
engle1147
You'll also need the "slip" additive.
Old Dec 9, 2008 | 07:13 PM
Aardwolf's Avatar
Aardwolf
Many lubes come with additive now, waste of money to add more. I use the Redline heavy shock proof and change it every other year or once a year depending on track use. I use a hand pump to remove it the pump in more.
Old Dec 9, 2008 | 11:47 PM
Redeasysport
Thanks guys very enlightening.
To D36 Lube?
