Double check my top end build
Old Dec 11, 2008 | 10:10 AM
imadirtguy's Avatar
imadirtguy
Default Double check my top end build
First car is 91 stock L98 that I use to autocross and track day 95%.
I just want to make sure that I'm not missing something before I order parts. Car only has 65,000 miles plan to leave bottom end alone. I know that not doing headers will leave some on the table but are a simple add down the road. I know I will need a custom tune.
Afr 180 23 65 cc heads
Comp cam 12-268-4 xfi
Holley stealth ram stock throttle body (see hood in sig)
30 lb injectors
catless exhaust with corsa cat back system
new 1.5 rockers
Thanks Jake
Old Dec 11, 2008 | 12:33 PM
rklessdriver's Avatar
rklessdriver
30 lb injectors
new 1.5 rockers
Thanks Jake
64cc combustion chambers are going to hurt your SCR.
Stock 113's are 58cc.
Will
Old Dec 12, 2008 | 10:58 AM
Z51L9889's Avatar
Z51L9889
You may want to consider having the heads milled 0.030" (reduces chamber volume 1cc per 0.006") to get a 60 cc chamber and then run a .039" or less head gasket thickness to get the compression ratio at or a little above stock.
Sounds like a good initial plan. You may also want to think about upgrading the exhaust to full duals when you eventually do the headers.
To Double check my top end build
