gears
Old Jan 17, 2002 | 12:06 AM
BowTieBlood's Avatar
BowTieBlood
Default gears
ok, if i was going to put 3.73 gears into my car what all would i have to do besides the gears and maybe a little rebuild kit in the back? easy to fix the speedo or is there any programming needed (lt1 auto)? easy task?
Old Jan 17, 2002 | 06:33 AM
93 ragtop's Avatar
93 ragtop
Default Re: gears (BowTieBlood)
92 and 93, you change the gears and sensor in the transmission. 94 up requires program such as hypertech.
Old Jan 17, 2002 | 10:48 AM
Hutch's Avatar
Hutch
Default Re: gears (Red 86 4+3)
You can replace the physical gears in a '94 and up as well, but reflashing the PCM is definitely easier and can give you added bonuses, as well. I don't think much of Hyperslop, though. Much better to send the PCM off for custom reprogramming by someone like Ed Wright at FastChip.
Old Jan 17, 2002 | 11:44 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
i put 375's in my vette.i purchased a speedometer calibrater in ecklers. it works on all 84-93's. retail was $169.99. good luck! :cheers:
To gears
