89 vette .bins on Moates
thanks, edl
89vets 6E.bin
ACSV 6E.bin
AJUL 6E.bin
Apkd1374 6E.bin
Apyn3496 6E.bin
APYP 6E.bin
APYU3516 6E.bin
Arap 6E.bin
AUJL 6E.bin
AUJM 6E.bin
AUJN 6E.bin
that is the problem i have with them, there is no indication they are modded, and not being familiar with what to look for, i'm shooting in the dark with them. that's why i was hoping somebody would say, oh yea, that's my bin and here are the specifics.
what i'm looking for is a conservative spark advance table for a miniram 377.
As a reminder, don't forget to re-calculate cylinder volume for your new tune...I'm sure you are probably familiar w/the rest
39.02 43.95 47.11 45.00 40.08 39.02 37.97 35.16 35.16 35.16 35.16 35.16
39.02 43.95 47.11 45.00 40.08 39.02 37.97 34.10 34.10 34.10 34.10 34.10
39.02 43.95 47.11 45.00 40.08 39.02 37.97 30.94 30.94 30.94 30.94 30.94
39.02 43.95 47.11 46.06 41.84 41.13 37.97 33.05 30.94 30.94 30.94 30.94
39.02 43.95 47.81 47.11 47.11 43.95 43.95 35.86 26.02 26.02 26.02 26.02
39.02 43.95 47.81 47.11 47.11 46.06 43.95 35.86 26.02 26.02 26.02 26.02
39.02 43.95 47.81 47.11 47.11 46.06 43.95 33.75 23.91 23.91 23.91 23.91
39.02 43.95 46.41 47.11 46.06 45.00 43.95 35.86 23.91 23.91 23.91 23.91
36.56 38.67 40.08 46.06 46.06 43.95 41.13 34.10 22.85 22.85 22.85 22.85
35.86 39.02 41.84 43.95 41.84 41.13 37.97 34.10 22.85 22.85 22.85 22.85
29.88 39.02 41.13 41.13 39.02 39.02 37.97 34.10 23.55 22.50 22.85 21.09
26.37 29.53 32.34 40.08 40.08 37.97 35.86 31.99 25.31 21.09 21.09 17.93
20.04 22.50 29.88 36.91 35.86 34.10 34.10 28.13 18.98 16.52 14.06 14.06
24.96 24.96 24.96 29.88 29.88 28.13 27.07 21.80 15.12 15.12 15.12 15.12
24.96 24.96 24.96 20.04 20.04 20.04 20.04 15.12 15.12 15.12 15.12 15.12
20.04 20.04 20.04 20.04 20.04 20.04 20.04 15.12 15.12 15.12 15.12 15.12
and PE v rpm
38.28
77.34
69.53
64.06
27.34
11.72
-7.82
-7.82
-17.19
-25.78
-21.10
-0.00
-0.00
6.25
6.25
11.72
11.72
i've sent Alvin some logs, should get a re-tune this coming week. like i said though, eventually i want to do my own tuning, so i've been comparing and trying to understand various bins.
i did make these changes to the spark table and felt a SOTP difference with no detonation.
47.11 47.11 47.11 45.00 40.08 39.02 37.97 35.16 35.16 35.16 35.16 35.16
47.11 47.11 47.11 45.00 40.08 39.02 37.97 34.10 34.10 34.10 34.10 34.10
47.11 47.11 47.11 45.00 40.08 39.02 37.97 37.97 33.05 30.94 30.94 30.94
47.11 47.11 47.11 46.06 41.84 41.13 37.97 40.08 35.16 31.99 31.99 31.99
48.16 48.16 48.16 47.11 47.11 43.95 43.95 45.00 36.91 34.10 31.99 29.88
48.16 48.16 48.16 47.11 47.11 46.06 43.95 46.06 40.78 35.86 31.99 29.88
48.16 48.16 48.16 47.11 47.11 46.06 43.95 44.65 39.73 33.75 30.94 29.88
48.16 48.16 48.16 47.11 46.06 45.00 43.95 42.19 39.02 31.99 29.18 27.07
46.06 46.06 46.06 46.06 46.06 43.95 41.13 42.19 40.08 29.88 26.02 24.96
43.95 43.95 43.95 43.95 41.84 41.13 37.97 34.10 33.05 29.88 26.02 24.96
41.13 41.13 41.13 41.13 39.02 39.02 37.97 34.10 35.16 29.18 23.91 22.15
29.88 29.53 40.78 40.08 40.08 37.97 35.86 33.05 30.94 27.07 23.20 21.09
20.04 29.88 40.08 36.91 35.86 34.10 34.10 28.13 26.72 24.61 20.74 20.74
24.96 24.96 24.96 29.88 29.88 28.13 27.07 26.37 24.26 20.39 20.39 20.39
24.96 24.96 24.96 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04
20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04 20.04
but, it is running VERY rich at WOT; AFR's in the low 9's!
i would like to see the compare bin you mention (eddie_d_lopez@hotmail.com).
thanks again mseven...
The MR is a special case as far as tune goes ;especially off idle stumble / backfires.
Have a look over on 3rd Gen
More tuners over there..... the F-body boys "adapt" their cars more than Vette owners
http://www.thirdgen.org/techboard/diy-prom/
http://www.thirdgen.org/techboard/di...hlight=miniram
As it stands you get a WB log and a Datamaster log but no reference to tie them together for analysis.
On the later ECM's they use a A/c signal input to get the signal in.
Rod,
I thought moates had the use of the lm interface using tuner pro rt w/the 165 resolved ? if not he will have to have to use the LM as a stand alone and w/rpm, correct.
Those target AFRs in the 9s may not really be as rich as they appear.
When the target AFR dips below approx. 11:1 you may exceed the pulse width limitation which is inherent in the bin's programming due to the order of operations in the pulse width calculation. An overflow occurs which limits the maximum pulse width before the injector constant is considered.
The result is a flat pulse width despite further increasing airflow or decreasing AFR targets. If you really require this much fueling, some special changes are required to get around the limitation, so its doubtfull that you're actually getting enough fuel to go below 11:1, unless this limitation has already been corrected for.
Since I never see this discussed, I assume that most are unaware of the phenomenon. It is more of an issue with supercharged cars, but could be a problem for a big inch N/A setup as well.
A note on datalogging: You can log the WB output signal with one of the ecm's MAP inputs. This of course, requires some programming changes in order to read the new input and add the signal into the data stream.
An easy way would be to correct the fuel pump voltage A/D channel read to the appropriate MAP sensor input to instead read the WB signal (since this is already in the data stream) and then rescale the signal in the datalogging software to the correct units for display purposes.
i'm going to look into the WB solution over the holidays; i've got two weeks off, so plenty of time for tinkering.
Here's the other manual flag in $6E that we discussed offline:
Note: The first value is the flag, the second is the offset. Set the flag to one and bump the offset from 5 to 10 (or 0x0A) for starters.
; MANUAL PARAMS
LC579 FCB 0 ; FLAG = 1 IF MANUAL, else = 0 <----<<<<<
LC57A FCB 5 ; 5 STEPS
ADDTED TO T/F IN DRIVE & x MPH
; MPH = LC545, 1.8 MPH.
Here's some more stuff related to CARS (CAGS):
The 4th gear N/V (rpm/mph) limits should be adjusted to fit the cars actual axle ratio.
This is also from the ARAP source hac (which is configured for an auto).
; GEAR DETERMINATION CALIB'S
LC291 FCB 255 ; 1st GR N/V Ratio
LC292 FCB 35 ; 4th gear MAX N/V ratio
LC293 FCB 30 ; 4th gear MIN N/V ratio
LC294 FCB 8 ; 0.8 sec, 4th gear timer
; CAL = Arg * 10, (8/10 Sec)
; CARS
LC295 FCB 255 ; 151c, CK CARS ACTIVE IF COOL GT THRESH
LC296 FCB 0 ; MPH/1 RESET SPEED FOR CARS
LC297 FCB 0 ; MPH/1 ENABLE SPEED FOR CARS
LC298 FCB 0 ; MPH/1 DISABLE SPEED FOR CARS
LC299 FCB 0 ; RPM/25 DISABLE SPEED FOR CARS
LC29A FCB 0 ; %TPS DISABLE TPS FOR CARS
Here are the settings From APYP 1989 6 speed 3.33/3.54:
LC291: 6E = 110 decimal ; 1st GR N/V Ratio
LC292: 61 = 97 decimal ; 4th gear MAX N/V ratio
LC293: 1E = 30 decimal ; 4th gear MIN N/V ratio
LC295: 78 = 120 = 70 C
LC296: 01 = 01 mph
LC297: 0C = 12 mph
LC298: 13 = 19 mph
LC299: 30 = 48 = 1200 rpm
LC29A: 5A = 90/255 = 35% tps
I've never tuned CAGS, but if it is still desired for some reason, I would consider reducing the tps threhold to something like 5% to disable it most of the time.
