Cold start question
Old Dec 14, 2008 | 05:31 PM
buddylee432's Avatar
buddylee432
Default Cold start question
I am looking for a cold start sensor because my motor does not have one on it. It is an 85 tpi. I looked at all of the auto part stores and online and cant seem to find one for sale. Can I just bypass the cold start sensor? If so what will be the effects?
Old Dec 14, 2008 | 05:49 PM
engle1147's Avatar
engle1147
The cold start or Termo switch is closed only when the engine is below ~120 F or so the 9th injector will fire. When the engine is warm or warmer the switch remains "open"(the 9th injector will not pulse). Your better off leaving the switch out than running a jumper wire around the switch.....you'll just have longer cold start crank times. Replacing the "thermo switch" with a new one would be the best option.
Old Dec 14, 2008 | 06:31 PM
buddylee432
Default cold start
Where do I find a thermo switch? I called the part stores and they dont have those.
Old Dec 14, 2008 | 06:44 PM
engle1147's Avatar
engle1147
http://shop.advanceautoparts.com/pro...ber=0280130229
http://www.ecklers.com/product.asp?p...2&dept_id=1241
To Cold start question
