Injectors
Old Jan 17, 2002 | 01:27 PM
Jim D's Avatar
Jim D
Default Injectors
I know this is a dumb question , but how do you get the clips off the top of injector, I'm sending them out to br reconditioned thanks Jim
Old Jan 17, 2002 | 03:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Injectors (Jim D)
I'm not sure if your clip is the same as mine: mine have a half-moon shaped clip with a tab near one end. I push the tab into the slot in the fuel rail to release the injector. Don't use too much force as the clips are a bit fragile and can be broken.
